Author Topic: 19" Screen Size PC Monitor in UK  (Read 3943 times)
NickS
  • Last login:September 11, 2014, 06:59:58 am
« on: June 30, 2002, 01:39:46 pm »
Hello,
I am looking for a 19" Screen Size PC Monitor to use in a Mame Based MS Pacman Style Cocktail cabinet. Can anyone recommend one ?. And idealy one that can be bought in the UK.
Thanks,
Nick.
Carsten Carlos
  • Last login:June 28, 2014, 05:06:25 am
  • Projects: Centipede extended, Asteroids
    • Carlos' Centipede-extended
Re: 19" Screen Size PC Monitor in UK
« Reply #1 on: June 30, 2002, 02:46:29 pm »
Personally I'd recommend the WellsGardner U3100, as long as you want a realistic arcade-look instead of the blockiness of PC-monitors. As it is an open-frame monitor, you additionally get a much better airflow in this position. It's not very suited for PC-games or typing your letters in Word though.
But it'd be better if someone else tells his opinion about this, too - I'm not neutral in this 'cause I've to sell one in Europe (Germany)  ;)
Anyway, if you wanna have a look at this thing look at my homepage under the monitor-sections. There are plenty of pictures about it.
Cheers
Carsten
Andy Geez
« Reply #2 on: June 30, 2002, 02:58:51 pm »
Hi,
E-mail Jeff Ferrier of Vektorlogic.com, ask if he has any 19" Wells Gardner VGA monitors left, he was selling these for
NickS
« Reply #3 on: July 01, 2002, 06:40:55 am »
Thanks for your replies.
How easy is to contect a WG arcade monitor to a computer ?. I was told that the refresh rates of Mame (particularli in Windows) can damage arcade monitors. do you know if this is correct ?
thanks,
Nick.
Andy Geez
« Reply #4 on: July 01, 2002, 06:52:45 am »
These monitors are designed for PCs, not to be confused with regular monitors.
They have a scan rate of 31.5khz meaning they support upto 720x480 at 60hz, possible to get 800x600 at 55hz
Simply plug and play as they use the standard DB15 VGA lead.
I hope that helps.
Zipper
  • Last login:May 11, 2024, 09:49:36 am
  • I've Built My Own Arcade Controls!!
« Reply #5 on: July 03, 2002, 06:18:39 am »
Hi,
I got a 19" SVGA POLO 2 monitor from http://www.hantarex.co.uk. Cost
