Author Topic: Rockola 450 Problem  (Read 1767 times)
mya2001
  • Last login:May 17, 2016, 01:41:06 pm
Rockola 450 Problem
« on: January 29, 2016, 04:05:49 pm »
Hi all this is my first post, looks like a really helpful forum
I've had this jukebox in my family for years but has not been used for a while. since I've started using again I noticed that when you make a selection it programmes the entry ok but after that the records will not automatically start spinning to find one, you can manually put it in scan then open to force it to spin and it will find it and play fine and any others that you've selected until it reaches the end of the spin, in the open space in the records then stop's again.
then having to reach in and go through the same process.
Hopefully it's not a major deal to fix :)
