Author Topic: Any one know the the dimensions the double dragon marquee?  (Read 2131 times)
Locke141
  • Never grow up.
« on: January 27, 2016, 09:55:48 am »
I want to have this printed locally in here in Nepal.
I imported it into photo shop and Illustrator and both say it's 98.167inch by 32.5inch. I need to get a handle on the size before I can
start building. Ideally I'ld have this printed up to help me plan. If it look good I may use it in the build if not I'Il order one.
If any one has just the the dimensions of the original marquee or better file than the one I found please let me know.
EDIT: I played around and looked on line. a with of 23 seem about right.
« Last Edit: January 27, 2016, 10:16:14 am by Locke141 »
danielm7999
  • Last login:January 11, 2017, 02:01:48 pm
    • Daniel Mercer Art
Re: Any one know the the dimensions the double dragon marquee?
« Reply #1 on: January 27, 2016, 11:19:28 pm »
On eBay there is a seller at 100% feedback selling an ORIGINAL Double Dragon marquee. In the description it says lists the dimensions:
"Up for auction is this vintage original NOS 1987 Double Dragon arcade game marquee translite by Taito. It is 23" x 7"."
Maybe that'll help..
- Daniel Mercer Art
JDFan
« Reply #2 on: January 28, 2016, 12:58:22 am »
Are you opening it in a 300 PPI setting or the default 72 PPI ??? chances are the image is 300 PPI and you are opening it at 72 PPI which results in the dimensions being 4.16 times larger than it should be !
SO the image you have if opened in 300PPI rather than 72 PPI would be 23.56 x 7.8 inches !
98.167/300 * 72 = 23.56"
32.5/300 * 72 = 7.8"
So will be the proper 23x7 with a bit extra black border if you print it at 300 PPI !
« Last Edit: January 28, 2016, 01:02:06 am by JDFan »
Locke141
  • Never grow up.
« Reply #3 on: January 28, 2016, 10:36:47 am »
Thanks guys,
I posted that questioned then soon after realize the DPI issue.
Here it is printed.
Not bad for $7.50
« Last Edit: January 28, 2016, 10:38:20 am by Locke141 »
danielm7999
    • Daniel Mercer Art
« Reply #4 on: January 28, 2016, 12:39:01 pm »
Nice man! Looks great, what did you print it on & where'd you have it done? I might have to try that for one of mine.
- Daniel Mercer Art
Locke141
  • Never grow up.
« Reply #5 on: January 31, 2016, 05:53:06 am »
Thanks men.
I'm in Nepal and it was printed at a local print shop. Its on a white plastic. It light through quite nicely.
lisowskikevin
  • Last login:April 02, 2024, 07:49:55 pm
  • If you take shortcuts, you get cut short.
« Reply #6 on: January 31, 2016, 09:06:21 am »
Just wanted to say great choice of game! DD was the first arcade game that I played and for me this game brings back so many memories! Oh the quarters and quarters I spent on this game.
Anyway goodluck with your build!
Locke141
  • Never grow up.
« Reply #7 on: February 01, 2016, 10:23:59 am »
Thanks lisowskikevin.
If any one else would like to comments please feel free to check out the build thread.
http://forum.arcadecontrols.com/index.php/topic,149284.0.html
