Author Topic: UltraStick Mapper plugin problem  (Read 5271 times)
MotoChi
  • Last login:December 15, 2016, 12:06:30 pm
« on: January 19, 2016, 11:21:07 am »
Trying to set up FatFinger's UltraStick Mapper plugin with Mala, and continuing to run into an issue.  Very stumped.
Versions:
Mala 1.82
UltraStick Mapper 1.3
Win 10
Everytime I start or exit Mala, a pop up window appears with the message:
"UltraMap by Ultimarc
Runt-time error '53':
File not found"
I turned on debugging with the plugin, not seeing anything obvious in the plugin log, also not seeing anything obvious in the Mala log.
UltraMap was installed into C:\Program Files (x86), and when manually running UltraMap, I do have to be administrator for the scan attached U360's to work.  I am wondering if that is the problem, and if so, what the suggested fix is.
My logs from starting Mala are below.  Thanks for any advice.
umapper.log
config loaded for MaLa UltraStik Mapper Version 1.3.00
Mala Directory: 'C:\arcade\mala\MaLa174'
UltraMap.exe: 'C:\Program Files (x86)\UltraMap\ultramap.exe'
UltraMap Options: ''
Debugging: 'yes'
EVENT: DllMain
EVENT: DllMain
EVENT: DllMain
EVENT: DllMain
EVENT: DllMain
EVENT: DllMain
EVENT: MaLa start
_build_mapname: Built map file name: 'C:\arcade\mala\MaLa174\Maps\mala.ugc'
_file_exists: Seeing if file 'C:\arcade\mala\MaLa174\Maps\mala.ugc' exists
_file_exists: 'C:\arcade\mala\MaLa174\Maps\mala.ugc' does exist
_run_ultramap: command line '"C:\Program Files (x86)\UltraMap\ultramap.exe" "C:\arcade\mala\MaLa174\Maps\mala.ugc" '
_run_ultramap: '"C:\Program Files (x86)\UltraMap\ultramap.exe" "C:\arcade\mala\MaLa174\Maps\mala.ugc" ' completed successfully
EVENT: DllMain
EVENT: DllMain
EVENT: DllMain
EVENT: DllMain
EVENT: DllMain
EVENT: Emulator selected
Name: M.A.M.E. v0.161 (Apr 29 2015)
EVENT: Game selected
Name: Robotron: 2084 (Yellow/Orange label)
Rom: robotronyo
Clone Of: robotron
Input Control: doublejoy
Manufacturer: Williams / Vid Kidz
Genre:
Year: 1982
EVENT: MaLa quit
_build_mapname: Built map file name: 'C:\arcade\mala\MaLa174\Maps\malaexit.ugc'
_file_exists: Seeing if file 'C:\arcade\mala\MaLa174\Maps\malaexit.ugc' exists
_file_exists: 'C:\arcade\mala\MaLa174\Maps\malaexit.ugc' does exist
_run_ultramap: command line '"C:\Program Files (x86)\UltraMap\ultramap.exe" "C:\arcade\mala\MaLa174\Maps\malaexit.ugc" '
_run_ultramap: '"C:\Program Files (x86)\UltraMap\ultramap.exe" "C:\arcade\mala\MaLa174\Maps\malaexit.ugc" ' completed successfully
EVENT: DllMain
MaLa-log.log:
2016/01/19  10:06:11.32   Info: ##########################################################################
2016/01/19  10:06:11.32   Info: Starting MaLa 1.8.2.0
2016/01/19  10:06:11.33   Info: LoggingLevel =  1
2016/01/19  10:06:11.33   Info: Starting usb LED/LCD device detection ...
2016/01/19  10:06:11.53   Info: Hardware: *** HidCtlDeviceChange ***
2016/01/19  10:06:11.53   Info: Hardware1: Creating object
2016/01/19  10:06:11.55   Info: Number Of Connected Hardware: 0
2016/01/19  10:06:11.55   Info: Finished usb LED/LCD device detection ...
2016/01/19  10:06:11.55   Info: Showing splash
2016/01/19  10:06:11.56   Info: Check plugin directory: C:\arcade\mala\MaLa174\plugins
2016/01/19  10:06:11.58   Info: Collecting event plugins (*.mplugin) in C:\arcade\mala\MaLa174\plugins\
2016/01/19  10:06:11.58   Info: Found event plugin LEDBlinky.mplugin
2016/01/19  10:06:11.58   Info: Event plugin LEDBlinky.mplugin loaded
2016/01/19  10:06:11.59   Info: Function: PluginName found
2016/01/19  10:06:11.59   Info: Function: PluginCopyright found
2016/01/19  10:06:11.59   Info: Event Function: LEDBlinky.mplugin MaLaGameSelected found
2016/01/19  10:06:11.59   Info: Event Function: LEDBlinky.mplugin MaLaEmulatorSelected found
2016/01/19  10:06:11.59   Info: Event Function: LEDBlinky.mplugin MaLaListSelected found
2016/01/19  10:06:11.59   Info: Event Function:   LEDBlinky.mplugin MaLaOrientationSwitch not found
2016/01/19  10:06:11.61   Info: Event Function: LEDBlinky.mplugin MaLaScreensaverStart found
2016/01/19  10:06:11.61   Info: Event Function:   LEDBlinky.mplugin MaLaScreensaverSwitch not found
2016/01/19  10:06:11.61   Info: Event Function: LEDBlinky.mplugin MaLaScreensaverStop found
2016/01/19  10:06:11.61   Info: Event Function:   LEDBlinky.mplugin MaLaAttractModeStart not found
2016/01/19  10:06:11.61   Info: Event Function:   LEDBlinky.mplugin MaLaAttractModeStop not found
2016/01/19  10:06:11.62   Info: Event Function: LEDBlinky.mplugin MaLaGameStart found
2016/01/19  10:06:11.62   Info: Event Function: LEDBlinky.mplugin MaLaGameQuit found
2016/01/19  10:06:11.62   Info: Event Function: LEDBlinky.mplugin MaLaStart found
2016/01/19  10:06:11.62   Info: Event Function: LEDBlinky.mplugin MaLaQuit found
2016/01/19  10:06:11.62   Info: Event Function: LEDBlinky.mplugin MaLaTreeUp found
2016/01/19  10:06:11.64   Info: Event Function: LEDBlinky.mplugin MaLaTreeDown found
2016/01/19  10:06:11.64   Info: Event Function: LEDBlinky.mplugin PluginConfigure found!
2016/01/19  10:06:11.64   Info: Event Function:   LEDBlinky.mplugin MaLaConfigureStart not found
2016/01/19  10:06:11.64   Info: Event Function:   LEDBlinky.mplugin MaLaConfigureStop not found
2016/01/19  10:06:11.65   Info: Found event plugin MaLaLauncher.mplugin
2016/01/19  10:06:11.65   Info: Event plugin MaLaLauncher.mplugin loaded
2016/01/19  10:06:11.65   Info: Function: PluginName found
2016/01/19  10:06:11.65   Info: Function: PluginCopyright found
2016/01/19  10:06:11.67   Info: Event Function:  MaLaLauncher.mplugin MaLaGameSelected not found
2016/01/19  10:06:11.67   Info: Event Function:   MaLaLauncher.mplugin MaLaEmulatorSelected not found
2016/01/19  10:06:11.67   Info: Event Function:   MaLaLauncher.mplugin MaLaListSelected not found
2016/01/19  10:06:11.67   Info: Event Function:   MaLaLauncher.mplugin MaLaOrientationSwitch not found
2016/01/19  10:06:11.69   Info: Event Function:   MaLaLauncher.mplugin MaLaScreensaverStart not found
2016/01/19  10:06:11.69   Info: Event Function:   MaLaLauncher.mplugin MaLaScreensaverSwitch not found
2016/01/19  10:06:11.69   Info: Event Function:   MaLaLauncher.mplugin MaLaScreensaverStop not found
2016/01/19  10:06:11.69   Info: Event Function:   MaLaLauncher.mplugin MaLaAttractModeStart not found
2016/01/19  10:06:11.70   Info: Event Function:   MaLaLauncher.mplugin MaLaAttractModeStop not found
2016/01/19  10:06:11.70   Info: Event Function:   MaLaLauncher.mplugin MaLaGameStart not found
2016/01/19  10:06:11.70   Info: Event Function:   MaLaLauncher.mplugin MaLaGameQuit not found
2016/01/19  10:06:11.72   Info: Event Function: MaLaLauncher.mplugin MaLaStart found
2016/01/19  10:06:11.72   Info: Event Function: MaLaLauncher.mplugin MaLaQuit found
2016/01/19  10:06:11.72   Info: Event Function:   MaLaLauncher.mplugin MaLaTreeUp not found
2016/01/19  10:06:11.72   Info: Event Function:   MaLaLauncher.mplugin MaLaTreeDown not found
2016/01/19  10:06:11.73   Info: Event Function:   MaLaLauncher.mplugin PluginConfigure not found
2016/01/19  10:06:11.73   Info: Event Function:   MaLaLauncher.mplugin MaLaConfigureStart not found
2016/01/19  10:06:11.73   Info: Event Function:   MaLaLauncher.mplugin MaLaConfigureStop not found
2016/01/19  10:06:11.75   Info: Found event plugin UltraStikMapPlugin.mplugin
2016/01/19  10:06:11.75   Info: Event plugin UltraStikMapPlugin.mplugin loaded
2016/01/19  10:06:11.76   Info: Function: PluginName found
2016/01/19  10:06:11.76   Info: Function: PluginCopyright found
2016/01/19  10:06:11.76   Info: Event Function: UltraStikMapPlugin.mplugin MaLaGameSelected found
2016/01/19  10:06:11.78   Info: Event Function: UltraStikMapPlugin.mplugin MaLaEmulatorSelected found
2016/01/19  10:06:11.78   Info: Event Function:   UltraStikMapPlugin.mplugin MaLaListSelected not found
2016/01/19  10:06:11.78   Info: Event Function:   UltraStikMapPlugin.mplugin MaLaOrientationSwitch not found
2016/01/19  10:06:11.80   Info: Event Function:   UltraStikMapPlugin.mplugin MaLaScreensaverStart not found
2016/01/19  10:06:11.80   Info: Event Function:   UltraStikMapPlugin.mplugin MaLaScreensaverSwitch not found
2016/01/19  10:06:11.80   Info: Event Function:   UltraStikMapPlugin.mplugin MaLaScreensaverStop not found
2016/01/19  10:06:11.80   Info: Event Function:   UltraStikMapPlugin.mplugin MaLaAttractModeStart not found
2016/01/19  10:06:11.81   Info: Event Function:   UltraStikMapPlugin.mplugin MaLaAttractModeStop not found
2016/01/19  10:06:11.81   Info: Event Function: UltraStikMapPlugin.mplugin MaLaGameStart found
2016/01/19  10:06:11.81   Info: Event Function: UltraStikMapPlugin.mplugin MaLaGameQuit found
2016/01/19  10:06:11.83   Info: Event Function: UltraStikMapPlugin.mplugin MaLaStart found
2016/01/19  10:06:11.83   Info: Event Function: UltraStikMapPlugin.mplugin MaLaQuit found
2016/01/19  10:06:11.83   Info: Event Function:   UltraStikMapPlugin.mplugin MaLaTreeUp not found
2016/01/19  10:06:11.83   Info: Event Function:   UltraStikMapPlugin.mplugin MaLaTreeDown not found
2016/01/19  10:06:11.84   Info: Event Function: UltraStikMapPlugin.mplugin PluginConfigure found!
2016/01/19  10:06:11.84   Info: Event Function:   UltraStikMapPlugin.mplugin MaLaConfigureStart not found
2016/01/19  10:06:11.84   Info: Event Function:   UltraStikMapPlugin.mplugin MaLaConfigureStop not found
2016/01/19  10:07:03.63   Info: Check backup directory: C:\arcade\mala\MaLa174\backups
2016/01/19  10:07:03.63   Info: Check to see if hook dll is required
2016/01/19  10:07:03.64   Info: Win98/ME Hook dll not loaded because OS is:
2016/01/19  10:07:03.64   Info: Computer name: MAME-PC
2016/01/19  10:07:03.68   Info: Loading config params from ini file
2016/01/19  10:07:03.74   Info: Setting params from ini file
2016/01/19  10:07:03.75   Info: Creating and loading mame cl conditions: C:\arcade\mala\MaLa174\mame.clc
2016/01/19  10:07:03.75   Info: Creating and loading mame info pages: C:\arcade\mala\MaLa174\mame.mli
2016/01/19  10:07:03.75   Info: Creating and loading other emu info pages: C:\arcade\mala\MaLa174\otheremu.mli
2016/01/19  10:07:03.77   Info: Creating and loading filter sets: C:\arcade\mala\MaLa174\mala.mlf
2016/01/19  10:07:03.77   Info: Creating and loading other Emulators: C:\arcade\mala\MaLa174\mala.mle
2016/01/19  10:07:03.77   Info: Collecting layout files (*.mll) in C:\arcade\mala\MaLa174\layouts\ccaper\
2016/01/19  10:07:03.77   Info: Creating and loading mala tree
2016/01/19  10:07:03.78   Info: Collecting game list files: (mlg) in C:\arcade\mala\MaLa174\
2016/01/19  10:07:03.78   Info: Creating and loading bios
2016/01/19  10:07:03.78   Info: LoadBiosList
2016/01/19  10:07:03.80   Info: Hiding taskbar
2016/01/19  10:07:03.80   Info: Muzac: Creating audio object
2016/01/19  10:07:03.82   Info: Muzac: Loading Playlist into Memory from FILE: C:\arcade\mala\MaLa174\mala.pls
2016/01/19  10:07:03.82   Info: LoadPlaylist: Playlist is empty
2016/01/19  10:07:03.82   Info: Muzac: Set in Sequential
2016/01/19  10:07:03.83   Info: Muzac: Set in No Loop
2016/01/19  10:07:03.83   Info: Hardware: Loading mala lcd screens
2016/01/19  10:07:03.83   Info: Hardware: Creating and loading mame lcd screens
2016/01/19  10:07:03.83   Info: Hardware: Creating and loading jukebox lcd screens
2016/01/19  10:07:03.85   Info: Creating and loading led config and attroct mode list
2016/01/19  10:07:03.85   Info: Collecting attract mode files (*.mlc) in C:\arcade\mala\MaLa174\
2016/01/19  10:07:03.85   Info: LoadGameList : Loading C:\arcade\mala\MaLa174\Favorites Landscape.mlg
2016/01/19  10:07:03.86   Info: Current Memory used: 24,800 K
2016/01/19  10:07:03.86   Info: Joystick 1 recalibrated
2016/01/19  10:07:03.88   Info: Hiding splash
2016/01/19  10:07:03.88   Info: SetLayout: Layout Name= ccaper_1080x1920
2016/01/19  10:07:03.89   Info: SetLayout: Loading layout: C:\arcade\mala\MaLa174\layouts\ccaper\ccaper_1080x1920.mll
2016/01/19  10:07:04.27   Info: Show Main Form
2016/01/19  10:07:04.28   Info: FormActivate:
2016/01/19  10:07:05.14   Info: FormActivate: Start initial delay
2016/01/19  10:07:05.16   Info: FormActivate:
2016/01/19  10:07:05.16   Error: FormActivate: CheckInFocus: NOT in focus. :-( Focus stolen by stolen by Untitled - Notepad
2016/01/19  10:07:05.18   Error: ForceFocus: CheckInFocus: NOT in focus. :-( Focus stolen by stolen by Untitled - Notepad
2016/01/19  10:07:05.19   Error: ForceFocus: CheckInFocus: NOT in focus. :-( Focus stolen by stolen by Untitled - Notepad
2016/01/19  10:07:05.19   Info: FormActivate: ForceFocus: Now back in focus using Method #2. :-)
2016/01/19  10:07:05.22   Info: FormActivate:
2016/01/19  10:07:06.43   Info: popMainPopup:
2016/01/19  10:07:06.43   Info: BuildGameListMenu: Adding New Menu 1 All Games
2016/01/19  10:07:06.43   Info: BuildGameListMenu: Adding New Menu 2 Favorites Landscape
2016/01/19  10:07:06.44   Info: BuildGameListMenu: Adding New Menu 3 Favorites Portrait
2016/01/19  10:07:06.44   Info: BuildGameListMenu: Adding New Menu 4 Most Played Games
2016/01/19  10:07:07.77   Info: FormClose
2016/01/19  10:07:07.78   Info: Plugins: Sent MaLa Quit message. (Plug-ins should now destroy its own Objects)
2016/01/19  10:07:07.78   Info: Plugins: ** Waiting for all plugins to quit **
2016/01/19  10:07:13.98   Info: FormActivate:
2016/01/19  10:07:14.57   Info: FormClose: Video1 Window now Closed
2016/01/19  10:07:14.57   Info: FormClose: Video2 Window now Closed
2016/01/19  10:07:14.59   Info: FormClose: Muazc Not Playing
2016/01/19  10:07:14.59   Info: Writing params to ini file
2016/01/19  10:07:15.67   Info: Muzac: Saving Playlist from Memory to FILE : C:\arcade\mala\MaLa174\mala.pls
2016/01/19  10:07:15.68   Info: Muzac: Saving Playlist. Number of Songs to save= 0
2016/01/19  10:07:15.78   Info: Screensaver: ScreenSaver Form Destroyed
2016/01/19  10:07:15.78   Info: FormClose: ShowTaskbar
2016/01/19  10:07:15.78   Info: Showing taskbar
2016/01/19  10:07:15.79   Info: Closing MaLa v1.82  * BETA * [1.8.2.0]
2016/01/19  10:07:15.79   Info: **************************************************************************
2016/01/19  10:07:15.81   Info: **************************************************************************
MotoChi
Re: UltraStick Mapper plugin problem
« Reply #1 on: January 20, 2016, 01:37:05 pm »
It appears the error I am getting is not related to Fat Finger's UltraStick Mapper, but purely related to UltraMap.  With that, this post probably isn't applicable under the Mala Section now, apologies.
I just tried running UltraMap command line, and got the same pop up error:
Run-time error '53':
File not found
Also tried running this in a command prompt where I start the command prompt "Run as administrator".  Same error.
UltraMap runs just fine in the GUI/Windows mode.  Only get this error running via command prompt.  Which is preventing implementing Fat Finger's UltraStick Mala plugin.
I have tried multiple uninstalls/reinstalls of UltraMap.
This is running under Win10, using latest version of UltraMap.
Have an email out to Andy to see if he might have any idea.
MotoChi
« Reply #2 on: January 20, 2016, 04:06:16 pm »
Okay, the problem is fixed now.
The ugc files that come with Mala are only set to program 2 U360's.  I have 3 U360's connected.  Once I opened each ugc file and set the 3rd U360 to use same map as the other 2 360's, and resaved the ugc file, all my error messages went away.
Everything is all good now!
