Author Topic: Width coil question  (Read 1713 times)
arcadepcnut
  • Last login:August 15, 2019, 12:03:07 pm
  • Warhammer 40K, you should try it.
    • BREAKTIME
Width coil question
« on: January 12, 2004, 03:48:13 pm »
http://www.dameon.net/BBBB/wc.html
I have the 3rd one from the left (the black one)on a monitor and it is broken. Ferite center has broken since it froze in place. I have many extra boards that I can salvage a width coil from but they all look like the second one from the left (the white one that looks like a thread spool).
Are they interchangable?
Thanks in advance!
Ken Layton
  • Guru
  • Technician
Re:Width coil question
« Reply #1 on: January 12, 2004, 05:50:40 pm »
Width coils are NOT interchangeable. Just like yokes and flybacks, they are made for specific makes and models of monitors.
If the coil is broken, order a new one from either Bob Roberts, Zanen Electronics, or the monitor manufacturer.
TIP: If the coil slug is glued or is stuck, blow the heat from a hair dryer on it for a couple of minutes to soften the glue/loosen the slug core. NEVER use an Allen wrench to turn the slug. Use plastic hex alignment tools (available at Radio Shack) only.
arcadepcnut
    • BREAKTIME
« Reply #2 on: January 12, 2004, 07:07:55 pm »
Yeah. I know that now (about what tools to use. It was frozen and the plastic adjust tool broke off in the hole). So I dont feel like I didnt try everything possible. Thanks for saving me some time with switching out the coils.
arcadepcnut
    • BREAKTIME
« Reply #3 on: January 13, 2004, 02:42:39 am »
Thanks. I found the part I needed from bob roberts. Not too expensive...I'll make sure to use plastic tools on this one ;)
Ken Layton
  • Guru
  • Technician
« Reply #4 on: January 13, 2004, 03:02:26 am »
Bob Roberts is an excellent source of replacement parts and general information.  8) His parts prices are very resaonable, too.  ;D
