Author Topic: Emulator problems  (Read 2156 times)
Duhjoker
  • Last login:August 29, 2016, 08:03:00 pm
Emulator problems
« on: January 17, 2016, 01:57:12 am »
        Using mala front end with a dell optiplex with 3450 graphics card. I had to turn the OS screen using catalyst and did some more config in mala to get the screen turned right for my cocktail cabinet. Every thing works fine but I downloaded and installed Fusion for sega game gear and when i start it from either mala or from its emu the full screen is going horizontal not vertical with everything else. I managed to turn the screen in fusion to the right direction but the controls are all funny. Up is left down is right and so on n the joystick.
The other thing I wanted to ask was if there is way a way to split screen nullDC for the fighting games so they are head to head on the cocktail?
« Last Edit: January 17, 2016, 04:22:05 pm by Duhjoker »
Duhjoker
Re: Emulator problems
« Reply #1 on: January 17, 2016, 04:25:07 pm »
   I could also use help getting psxfin to go to full screen. I read somewhere about changing an F switch? It also had a link to follow to tell you how but that link is dead. Does anybody know how to do this?
I am literally running around in circles trying to find out how to change the switches.
« Last Edit: January 17, 2016, 04:50:28 pm by Duhjoker »
stigzler
    • Mago Arcade
« Reply #2 on: January 17, 2016, 05:55:54 pm »
Duhjoker
« Reply #3 on: January 17, 2016, 06:05:59 pm »
Ok the front apps, is this a background type? Will I still be able to access psxfin through my mala front end?
I solved the problem with the joystic controls on the fusion I just reversed the controls L & R are up and down and up down left and right.
Now if could get nullDC to split screen I would set.
« Last Edit: January 17, 2016, 06:10:05 pm by Duhjoker »
stigzler
    • Mago Arcade
« Reply #4 on: January 18, 2016, 05:42:40 am »
Dunno. Try it. And, you're welcome.
Duhjoker
« Reply #5 on: January 18, 2016, 03:45:55 pm »
 Yes thank you!!!!!
Duhjoker
« Reply #6 on: January 20, 2016, 03:57:42 am »
   I tried the front end app but could not get it to work. But if some one knows the correct commamd line i can enter that into the mala command line for that emu and it should work. It worked for nulldc at least.
I tried a couple combinations i found on previous posts but none worked.
