Author Topic: Finished my first 2 Player Bartop Arcade cabinet and 2 Player control panel  (Read 1733 times)
xantari
  • Last login:January 16, 2021, 06:55:05 pm
  • Browsing aroud!
So I learned a lot throughout this whole project. Main lesson. This takes a TON of time :-)
Anyways, it was very fun to do. Just need to work on the software side of things now that the hardware stuff is mostly done (still need to get the wiring under control).
If anyone is viewing this, and has any ideas on fixing the interference in my Lepai 2.1 channel amp, I am all ears. I tried everything and broke down to getting a Logitech Z313 that I took apart to power the speakers and 2" sub. Yeah 2" sub. But it helps, as the front speakers are all treble. And as Meghan Trainor knows, its all about the bass.
Got around to documenting the 2 player control panel and the 2 player bartop arcade cabinet today and posted the video walkthrough on YouTube.
2 Player control panel:
2 Player control panel was a DIY one from Monster Arcades
All buttons are ClassicRGB by Ultimarc and hooked up to an I-Pac Ultimate.
Ultimarc U-Trak with RGB Light addon
Meanwell 15 Watt, 5 Volt power supply
Ultimarc Spinner
Zippy Joystick in 4-way mode
2 happ joysticks
2 Player bartop arcade cabinet:
2 Player Bartop DIY Kit from Monster Arcades
2 Coats of Primer, 3 Coats of high gloss sherwin williams enamel white paint. All sprayed using a cheap Graco sprayer.
All RGB Buttons from Ultimarc
I-Pac Ultimate
850 Watt Power Supply
Thermaltake Red Ring Fan
Custom piano hinged control panel and back panel
ASRock H97M with GeForce 960, 16GB RAM, 256GB SSD
Logitech Z313 to power 2" speakers and 2" sub
Monitor bezel made from two sandwiched together laminating film from office max and spray painted black ($6.00 USD)
Lock down hinges for control panel
« Last Edit: January 16, 2016, 02:49:49 am by xantari »
lowlytech
  • Last login:February 07, 2019, 08:12:12 am
I have the same 2.1 Lepai amp for my build which I planed to power from the PC power supply.  I could not get the hard drive interference in the speakers to go away until I changed to a small 12 volt dc adapter that is plugged into the shared power strip inside the cab.  However I had to switch to a shielded RCA cable cause I was still getting hum.  Now it sounds pretty good.
Congrats on getting your build finished.  I have been working on and off with mine for 2 years and finally getting past a few hurdles that have held me up.  Maybe soon I can wrap mine up.  Good luck on the audio amp, hopefully your interconnect might be the culprit.  Mine acted like a big antenna to pickup hum and noise until I switched to a shielded type cable.  Unfortunately I gave up trying to power it through the PC power supply however.
lowlytech
Had another update on the Lepai amp.  I upgraded my power supply from 1.5 to 2 amps the other day and I started getting buzzing and noise out of the speakers with the new supply.  It probably wasn't the amps, but I noticed the 2A power supply didn't have a ferrite core on the DC power supply line and the 1.5A did.  This must be part of the equation on the audio noise maybe?  Make sure you have a ferrite core on your power supply and see if that helps.
