Author Topic: Feedback on my new cab  (Read 3296 times)
dogg0
  • Last login:December 14, 2014, 01:18:29 pm
  • ALL? no ALL!!!
« on: January 12, 2004, 12:03:22 pm »
Please leave positive feedback only! j/k.... :-\
It also doubles as a TV STAND!
thou shalt not supress flatulence
-the bassmaster general
Sephroth57
  • Poo Monkey
  • Last login:June 07, 2020, 11:17:00 am
    • Check it out!!!
Re:Feedback on my new cab
« Reply #1 on: January 12, 2004, 12:21:20 pm »
its pretty cool, id prefer something a bit taller i like standing when i play and that thing doesnt look like youd want to shake it a lot with a frantic fighting game
"Owens is the ringleader in the ass hat circus"  D K
jelloslug
  • Last login:May 25, 2005, 03:55:59 pm
  • Splut!
    • Jelloslugs Arcade
« Reply #2 on: January 12, 2004, 12:30:48 pm »
Nice!  If you ever want to upgrade the TV you won't have to rework the cabinet ;D
gprime
  • Last login:November 02, 2024, 01:23:19 pm
  • still the newb
    • G-Prime .NET
« Reply #3 on: January 12, 2004, 12:44:51 pm »
that looks like the tv i used in my cab! is that a 20" prima w/ s-video?
edit:
nevermind it looks slightly different, and yours is a flat screen
« Last Edit: January 12, 2004, 12:46:10 pm by gprime »
Serpent
  • Last login:December 02, 2003, 03:34:39 am
« Reply #4 on: January 12, 2004, 05:16:34 pm »
Intelligent design. This way you can rotate your TV manually anytime you want to play vertical games. It's similar to my proyect. However, mine will be a sit down cabinet with removable control panel. What brand of TV is that? It looks like a 21". I'll be using a 21" Thomson with SCART socket.
dogg0
  • ALL? no ALL!!!
« Reply #5 on: January 12, 2004, 06:08:14 pm »
Its actually a sony wega (i think) 20" flat screen. One problem with the tv though is that it doesn't have s-video. It does have composite video though. I ordered some kind of pc/tv converter instead of using a video card with tv-out. Once that comes in im going to take a look and try to get a cable that will output to composite video.I was thinking of rebuilding the top and partly sinking the tv into the stand at an angle. I guess that will be next project. Also on the bottom where i just put that marble contact paper, I am planning on putting daimond plated steel as kick plate. I think it would be cool if the monitor was sunk in and you would look down when you play.
Ren Hoek
  • Last login:June 27, 2014, 01:18:16 am
  • "Hasta la vista, eediot!"
« Reply #6 on: January 12, 2004, 10:30:38 pm »
I like it.  Leaves a lot of room for alteration (such as a 2-piece cab).  You could make a top shell eventually and easil fasten it to the top.  It's obviously currently just a glorified control panel, but that's not a criticism.
HagHore
  • Last login:October 24, 2007, 02:24:00 pm
  • Game Over Man, Game Over!
« Reply #7 on: January 12, 2004, 11:16:15 pm »
That's nice and similar to an idea I had for a couple of cabs I want to get made for my brothers (cost savings in mind).  I want theirs to be a full size so an adult can stand and play at the controls, but I want to keep construction costs down as well, so I was planning on using the Pacman style cab only from the monitor on down, getting rid of all the overhead stuff.
We're on an express elevator to Hell! Goin' down!
