Author Topic: wg9200 vs sharp SI-134svga ? opinnions  (Read 3307 times)
tommycoins98
« on: July 04, 2002, 08:35:34 pm »
hi folks, I want to buy a 33"monitor svga because make a rotable 27" its too hard to make a rotable device and heavy, i want to know if somebody have a sharp image SI-134Svga, in the specs dont say if the this monitor comes with a db15 input, only say rgb  and suport 800x600 and 1024 x768(I),and freq its 31.5 to 48.5 Khz,and rca tube invar mask,for vert and horz mounting,but the  video characteristics bandthwith say (-3db)12 mhgz tipical and the bandwith say 40-60 Mhz?
and the wgd9200 33"comes with 2 inputs(rgb and db15) but only support 600x480, and the freq its 15 to 31 khz ,and rca tube(the sharp its the same rca or sony A tube)
for you which its the best options?
and if i have the 33 " svga monitor , i want to know the maximiun size in verticals games, (ej 20 " for 27 " etc...)
with move and play the resolutions of course,
A 33 " MONITOR  ITS THE BEST OPTION VS 27 ROTABLE MONITOR,(SIZE IN VERTICAL GAMES, AND DIFICULTY TO MAKE A ROTABLE DEVICE, DANGER AND HEAVY)
THE 33" ITS IN A NORMAL POSITION(NO ROTABLE)
THANKS
