Author Topic: VGA vs DVI port for CRT Emudriver  (Read 6285 times)
pacboy
  • Last login:December 24, 2019, 09:18:52 am
« on: January 13, 2016, 01:28:08 pm »
I read that it is preferred to use a Radeon card with a VGA port as opposed to one with a DVI-I + DVI to RGB adapter with CRT Emudriver.  Is the signal quality better with the VGA port?
haynor666
  • Last login:January 09, 2026, 02:33:07 pm
  • retro maniac
Re: VGA vs DVI port for CRT Emudriver
« Reply #1 on: January 13, 2016, 01:46:47 pm »
DVI is usually seen on PC as first port. This should matter only on XP. Many cards have VGA port connected through ribbon cable, such connection reduces picture quality.
pacboy
« Reply #2 on: January 13, 2016, 02:09:27 pm »
I'm not sure what you mean.  I'd like to use Windows 7 with CRT Emudriver 1.2b (Catalyst 13.1).  They say it supports up to the Radeon HD 4xxx cards.  Every HD 4xxx card that I look at only have DVI-I ports.  I'd like to use the HD 4xxx series because they are the fastest supported cards.  Aren't the VGA signals coming through a DVI-I to VGA adapter the same quality as signals coming from a card with a native VGA port, or am I missing something?
haynor666
  • retro maniac
« Reply #3 on: January 13, 2016, 02:17:39 pm »
Look:
VGA straight from PCB - very good picture quality
VGA through ribbon cable - not so good picture quality
In both cases DVI-I will output the same quality picture as VGA (on PCB) on picture 1.
« Last Edit: January 13, 2016, 02:25:05 pm by haynor666 »
Calamity
  • Moderator
  • Last login:Yesterday at 05:28:27 pm
  • Quote me with care
« Reply #4 on: January 13, 2016, 02:22:38 pm »
I have the exact second one, I never noticed any issues with picture quality (don't mean there aren't). Of course I couldn't compare with the other.
Pacboy, the HD 4xxx series are not the fastest cards supported any more, check this: http://geedorah.com/eiusdemmodi/forum/viewtopic.php?id=295
Steps to create a log:
haynor666
  • retro maniac
« Reply #5 on: January 13, 2016, 02:27:04 pm »
It's hard to spot difference on lowe res TV/arcade monitor but very easy on typical PC CRT monitor. It's harder to see this problem on LCD because (I think) most LCD have some kind of picture correction.
pacboy
« Reply #6 on: January 13, 2016, 02:38:59 pm »
Awesome, thanks!  So the fastest cards that'll work at this point in time would be the HD 7xxx series with Win 7 or 8, correct?  Do you have any plans to make even more recent cards compatible or is this it for a while (I'm about to buy a card)?
Regarding the VGA vs DVI-I port, I think I'll need to use a DVI-I to VGA adapter because they stopped putting VGA ports on the Radeon cards a long time ago, definitely not on the HD 7xxx series, correct?
haynor666
  • retro maniac
« Reply #7 on: January 13, 2016, 02:53:27 pm »
The are still graphics cards even modern ones with VGA but mostly economical or OEM.
BTW. Why You need very fast card?
pacboy
« Reply #8 on: January 13, 2016, 03:07:07 pm »
I'm not sure that I do, but I'm building a new custom PC so I want to use the fastest parts that are available.
haynor666
  • retro maniac
« Reply #9 on: January 13, 2016, 03:45:19 pm »
In case of mame or any other 2D system emulator is pointless.
Jollywest
  • Last login:Today at 01:56:48 am
« Reply #10 on: January 15, 2016, 02:10:41 am »
Thanks for this, just tried it on my 4350 with Ribbon cable and the DVI port (with VGA adapter) is quite noticeably better on a Hantarex Polo 25" 15khz arcade monitor... It's a lot brighter and sharper too, cheers 👍
xga
  • Last login:September 24, 2024, 09:01:04 am
« Reply #11 on: January 17, 2016, 07:48:32 am »
Can anyone recommend any quality DVI to VGA adaptors?  I purchased a few off eBay for a friend, but the quality was terrible (wavy lines and noise) so I gave him the one that came with one of my ATI cards.  The difference was very noticeable.
Jollywest
« Reply #12 on: January 17, 2016, 09:28:46 am »
I'm using one that came with my ASUS P5Q motherboard, I would of thought it's ASUS branded but has nothing written on it and it works great.
