Author Topic: Radeon HD 7990 - CRT Emudriver 2.0  (Read 2225 times)
dk_no1
  • Last login:April 24, 2022, 02:46:52 am
« on: January 12, 2016, 08:02:22 pm »
Tried the new drivers with a radeon HD 7990, but the installation fails.
The hardware ID is:
PCI\VEN_1002&DEV_679B&SUBSYS_0B2A1002&REV_00
PCI\VEN_1002&DEV_679B&CC_038000
i can see in the atiilhag.inf that the lines:
PCI\VEN_1002&DEV_6798
PCI\VEN_1002&DEV_679A
already are there, but the PCI\VEN_1002&DEV_679B is not.
can I do anything to make it work?
Calamity
  • Moderator
  • Last login:July 19, 2025, 04:03:33 am
  • Quote me with care
Re: Radeon HD 7990 - CRT Emudriver 2.0
« Reply #1 on: January 13, 2016, 10:09:16 am »
I've added your pci id to the driver, get it here.
Steps to create a log:
dk_no1
« Reply #2 on: January 13, 2016, 03:41:43 pm »
Thanx for the driver update and your big effort in this great project.
Now the driver installs. ;D But it does not work.
Tried with windows 7 64bit, and it looks like the digital part
is ok, but the analog part gives an error 43.  :( So it can't see the PAL TV.
Also tried with Windows 8 64bit, but here it gives an error 43 on both,
and defaulting to the internal Microsoft gfx driver, so no luck here.  :cry:
Calamity
  • Moderator
« Reply #3 on: January 13, 2016, 05:15:33 pm »
Ok, I'm seeing the Crimson driver inf and the 679B device is configured as ati2mtag_NewZealand, which is absent from the driver I'm using, so it's probably not supported at all. Don't worry, it should be supported in the near future, don't throw that card away. Thanks for testing.
dk_no1
« Reply #4 on: January 13, 2016, 05:49:03 pm »
No problem 8)
I will be ready for test anytime you need it. :)
