Author Topic: CRT Emudriver 2.0 Win7 blurry 640x480 60i  (Read 21470 times)
R-Typer
  • Last login:September 09, 2024, 12:50:41 pm
  • C64 Rulez!!!!
Re: CRT Emudriver 2.0 Win7 blurry 640x480 60i
« Reply #40 on: January 06, 2016, 04:39:54 pm »
Hi Tom,
I use Snes9x 1.53 since it has support for both OpenGL and Direct3D instead of old DirectDraw. You can set the low resolutions as well. It was last updated in 2011 so it the latest SNES emulator I know of.
ktnxbai
« Last Edit: January 07, 2016, 03:50:42 pm by PL1 »
tom5151
  • Last login:September 16, 2023, 09:21:11 am
« Reply #41 on: January 06, 2016, 04:41:46 pm »
Calamity
  • Moderator
  • Last login:Today at 09:35:04 am
  • Quote me with care
Steps to create a log:
tom5151
« Reply #43 on: January 07, 2016, 04:12:20 pm »
Thanks a lot @Calamity, you're definitely the one  ;D
I just tested and it's working fine with 2.0b5 :applaud:
haynor666
  • Last login:November 21, 2025, 05:45:00 pm
  • retro maniac
« Reply #44 on: January 11, 2016, 03:25:25 pm »
I have also issue with blurry picture on 5450 - looks like odd and even lines are in fact the same lines. Similiar trick I use in amiga 1200 long time ago to reduce flickering. With 4350 on Homura (Taito Type X game) interlacing was clearly visible but on 5450 flickering is very low. In fact every interlaced mode looks like this.
« Last Edit: January 11, 2016, 03:27:26 pm by haynor666 »
R-Typer
  • C64 Rulez!!!!
« Reply #45 on: January 11, 2016, 04:00:05 pm »
I had exactly this problem on a radeon x300 and I have it now with msi radeon 7770.
Calamity
  • Moderator
« Reply #46 on: January 11, 2016, 04:13:32 pm »
They're not the same lines, if it was that it would look very blocky. Instead, both lines look interpolated by a bilinear filter.
haynor666
  • retro maniac
« Reply #47 on: January 30, 2016, 09:15:34 am »
Since ArcadeVGA is now HD5450 can anyone confirm that this blur picture is also on ArcadeVGA? If not then probably there is a way to fix this.
MuguiWara
  • Last login:December 10, 2017, 03:36:38 pm
« Reply #48 on: February 16, 2016, 04:32:46 am »
hi,
I'm using the same card as the OP here (HD6850) with two different hardware.
One is flash with ATOM15 because i need to plug it directly to the VGA of an MS2930(blast city),
And the other is not flashed (no need, going trought a jammasd), and hooked to a 18" toshiba (capcom cute).
The desktop resolution (640x48i 60hz) is clean for both setup.
I'm just noticing a slight difference with groovymame refresh rate compared to my old HD4890 (emudriver1).
For example with Street fighter 3.3 switchres is choosing a 59.82hz instead of the original 59.83xxx one (was exact for the HD4890 oldemudriver).
I'm alway have few 10^-2 hz less difference for each games for the refresh rate.
Is it a normal behavior?
« Last Edit: February 16, 2016, 05:52:51 am by MuguiWara »
Calamity
  • Moderator
« Reply #49 on: February 16, 2016, 05:14:28 am »
Check this thread: http://forum.arcadecontrols.com/index.php/topic,149585.0.html
MuguiWara
« Reply #50 on: February 16, 2016, 05:25:44 am »
Thank's for the information.
If i understand it correctly, the old way was displaying the desired refresh rate and the new way display ( maybe by error) a rounded dotclock value?
Otherwise it was never the actual refresh rate so same difference  ;D
« Last Edit: February 16, 2016, 07:31:39 am by MuguiWara »
Calamity
  • Moderator
« Reply #51 on: February 17, 2016, 05:34:04 am »
Exactly.
