Author Topic: GroovyMame - Windows XP vs Windows 7  (Read 39087 times)
buttersoft
  • Last login:Today at 02:01:17 am
  • Is running at 15kHz
Re: GroovyMame - Windows XP vs Windows 7
« Reply #40 on: October 20, 2017, 02:07:01 am »
Weird setup you have now. That CPU seems much newer and more advanced than the GPU?
The 6450 needs the (correct) crt_emudriver version for Win 7 or Win 10. If you can use that card in the machine you already have, and install win7 on it, everything on your list will run fine.
Give it a go before you spend money, at least :)
Thanks for your reply, buttersoft! :)
Now, my CPU is a Xeon X3380m. I have an ATI X300 graphic card and 4GB ram. Mame version is 0.158. My OS is XP PRO 64 bits. I saw Windows 7 is better than XP about input lag so I wonder if I can find a better CPU and the best MB to play on Win 7 as I played exactly on original CPS and MVS and some 3D games as Radiant Silvergun.
Another question: is it possible to have Calamity drivers with my HD6450 on XP or is it just for Windows 7?
I'm sure Calamity has the perfect set (CPU, MB, GPU etc...) but he keeps the secret... :D
« Last Edit: October 20, 2017, 02:12:16 am by buttersoft »
folken
  • Last login:February 24, 2019, 08:28:37 am
« Reply #41 on: October 21, 2017, 10:54:33 am »
As you can see on this web page my CPU is old (1stQ 2009)
https://ark.intel.com/fr/products/41094/Intel-Xeon-Processor-X3380-12M-Cache-3_16-GHz-1333-MHz-FSB
But yes, i think X300 GPU is older  :D This GPU is very weird: before installing CRT_Emudriver it's an X300, after installing it transforms itself in X1050... ???
I've tried to install CRT_emudriver on the HD6450 (Windows XP) but it doesn't work :(
« Last Edit: October 22, 2017, 03:29:42 am by folken »
Amplifuzz
  • Last login:November 24, 2018, 09:30:46 pm
« Reply #42 on: October 21, 2017, 09:47:43 pm »
This GPU is very weird: before installing CRT_Emudriver it's an X300, after installing it transforms in X1050... ???
Had the same thing happen to me, but the card works fine regardless of the name, up until GM 0.171 at least.
folken
« Reply #43 on: October 22, 2017, 03:07:29 am »
My Mame version is 0.158.
haynor666
  • Last login:January 09, 2026, 02:33:07 pm
  • retro maniac
« Reply #44 on: October 22, 2017, 05:27:57 am »
Please use Radeon HD4xxx cards or newer. Such old hardware might not work correctly even with official mame.
folken
« Reply #45 on: October 22, 2017, 10:28:34 am »
My arcade box works very good but I'm sure I could have a better one...  ;) I bought an HD6450 2Go several weeks ago. I want to use Windows 7 pro 64. Now I need to know what is the most powerful CPU with the perfect mobo and Ram to play 2D games as original arcade hardwares.
What do you think about Intel I7-7820X with an X299 mobo? I've read somewhere in emulation, games don't use GPU but ONLY CPU... Is it right?
« Last Edit: October 22, 2017, 03:30:13 pm by folken »
buttersoft
« Reply #46 on: October 22, 2017, 07:25:05 pm »
I'm starting to feel like a broken record...
Have you even tried loading Win 7 on your current setup + 6450? Everything on your 2D list will run fine on that machine you already have, without glitches and without slowdown. I'm using an E6600 2.4Ghz Core2Duo in one of my cabs, and it's overpowered for 90% of what you want. Is the problem that you can't get the 6450 into your current machine or something? I don't get why you're so keen to spend money.
If you use your current setup, and for some unfathomable reason it has problems, you can just take the hard drive out and plug it straight into the next machine - assuming you keep the GPU remotely similar - there will be no need to reconfigure anything beside the joysticks/controls.
To answer your other question, MAME, and thus GM, only uses the CPU. The GPU is needed to push a video mode, nothing more. This is the case with a lot of older emulators, but something newer like Teknoparrot or maybe Demul might need a bit of GPU grunt too.
5XXX and newer, dude. 5XXX and newer.
folken
« Reply #47 on: October 23, 2017, 11:26:18 am »
I'm sorry about that buttersoft! I will try to explain clearer ;)
No, I don't want to spend money if games don't need. Maybe my settings are not optimized. Here they are in VMMaker for my Sony PAL TV:
VMMaker format: monitor_specs0 15625-15750, 49.50-65.00, 2.000, 4.700, 8.000, 0.064, 0.192, 1.024, 0, 0, 288, 448
So when I play an MVS game there is no problem, Switchres is: 320X224p 59.186 Hz 15.625 khz
But when I play a CPS III game (SF3.3), Switchres is:
384X224p 59.183 Hz 15.670 Khz instead of 15.432 Khz which is the horizontal rate of the CPS III so maybe I need .ini file for each system (CPS III and MVS etc...).
If I want a 15.432 Khz horizontal rate in CPS III games I must change this line in:
VMMaker format: monitor_specs0 15432-15625, 49.50-65.00, 2.000, 4.700, 8.000, 0.064, 0.192, 1.024, 0, 0, 288, 448
 What do you think about that? :)
« Last Edit: October 23, 2017, 04:00:04 pm by folken »
Calamity
  • Moderator
  • Last login:February 19, 2026, 06:15:36 am
  • Quote me with care
« Reply #48 on: October 23, 2017, 04:16:29 pm »
CPS III games won't look any better at 15.432 kHz than they do at 15.625.  When using a monitor with adjustable hfreq range, setting it up for low hfreq frequencies limits the maximum hfreq it can sync, making it worse for vertical games.
With regards to "the best" hardware for GM, it all comes down to the best CPU you can afford. As for the GPU, you're fine with that 6450.
Steps to create a log:
folken
« Reply #49 on: October 24, 2017, 05:10:22 am »
So, if I understand you game with 15.432 Khz or 15.625 Khz horizontal rate is the same?
What is the best OS to run GM as original hardware? XP or 7?
buttersoft
« Reply #50 on: October 24, 2017, 09:40:40 pm »
I'd go with Win 7, it's easier to get things to run, and to get any utilities or extras on - like joytokey, or AHK, if you ever need them.
fcobenitez
  • Last login:May 23, 2022, 12:36:40 pm
« Reply #51 on: October 29, 2017, 08:52:37 am »
Very interesting thread, many good recommendations.
I also want to build a new dedicated groovy Mame PC for my aero city (last one was pretty old, 3.0 GHz Pentium 4, 2 GB Ram, and an archaic Raden 9250 card, but it worked pretty good for most games.
Now that I want to build a new setup, I'm thinking about using my old Phenom 965 Black Edition, which can be overclocked over 4ghz with ease, but I know I've read that AMD processors won't perform as good as an Intel one with MAME. It's this still the case, or with high end processors (or one that used to be hehe) like the 965 at high clock freqs won't have problems? Most demanding games I will play are maybe Demul, only if possible, if not I'm happy with playing anything up to STV.
(Still got to get a VGA)
folken
« Reply #52 on: November 12, 2017, 04:40:01 pm »
Can you tell me why my HD6450 is not recognized by XP Pro 64? Instead of the card name XP says:"VGA device" if I remember...
haynor666
  • retro maniac
« Reply #53 on: November 12, 2017, 05:19:17 pm »
Driver for windows XP is for HD4xxx maximum. It won't install cards HD5xxx and newer - http://geedorah.com/eiusdemmodi/forum/viewtopic.php?id=65
folken
« Reply #54 on: November 13, 2017, 12:36:34 am »
So I must install WINDOWS 7?
haynor666
  • retro maniac
« Reply #55 on: November 13, 2017, 02:01:14 am »
If You need groovymame to work with this card than You have to install windows 7 x64. XP as development system is abandoned
There is of course official AMD driver but with this one groovymame will not utilize all it's capabilities.
keilmillerjr
  • Web Developer.
« Reply #56 on: November 13, 2017, 11:05:47 am »
Install windows 10. Why the hell do you want to run an OS that's 16 years old, had support for over a decade, and now abandoned?
haynor666
  • retro maniac
« Reply #57 on: November 13, 2017, 11:09:22 am »
The minimum will be windows 7 x64, windows 10 x64 is also an option but I prefer less memory hungry system (I have machine with 2 Gb). Though XP is not supported mame still works fine on XP and I think it will work for years on windows 7.
Keep in mind that some stuff like emulators or games might not work correctly for example Taito Type X (erratic speed under windows 10) games or Ootake emulator (cannot switch resolutions on windows 7, Calamity long time publish modified version).
« Last Edit: November 13, 2017, 02:38:19 pm by haynor666 »
Calamity
  • Moderator
« Reply #58 on: November 13, 2017, 04:13:54 pm »
IMHO it would be more productive to press emulator authors to fix their buggy emulators instead of sticking to old OSes. If they're not interested or their projects are abandoned, switch to an alternative.
folken
« Reply #59 on: November 16, 2017, 11:28:33 am »
Bonjour Calamity! :)
How to be sure Groovymame using good modelines, good pixel clock (MVS=6 Mhz, CPSIII= 7,5Mhz), good Horizontal and Vertical f.porchs, b.porchs and syncs?
Paradroid
  • Last login:December 05, 2025, 10:28:19 pm
    • SCART Hunter
« Reply #60 on: November 16, 2017, 03:40:14 pm »
Try here: http://geedorah.com/eiusdemmodi/forum/viewtopic.php?pid=328#p328
My MAME/SCART/CRT blog: SCART Hunter
folken
« Reply #61 on: November 17, 2017, 03:27:44 pm »
Thank you paradroid but when I use this modeline in my Mame.ini for NEO GEO MVS on my PAL Sony TV :
"320x224_60 15.625KHz  59.185606Hz" 6.000 320 327 355 384  224 240 248 264 -hsync -vsync
My tv screen is totally blurred with violet and green colors squares.. :o
« Last Edit: November 17, 2017, 11:47:41 pm by folken »
haynor666
  • retro maniac
« Reply #62 on: November 18, 2017, 02:00:53 pm »
What exact model You are using? I'll trinitrons I have/had correctly work from 49,5 Hz to 61 Hz.
folken
« Reply #63 on: November 20, 2017, 04:31:33 am »
KV-E3431B/2
haynor666
  • retro maniac
« Reply #64 on: November 20, 2017, 10:56:16 am »
Judging from covers for manual this tv can operatore from 50 Hz to 60 Hz safely.
Just try set arcade_15 in mame.ini.
folken
« Reply #65 on: November 20, 2017, 01:17:56 pm »
"Custom" is set in my Mame.ini.
I'll try "Arcade_15" ;-)
haynor666
  • retro maniac
« Reply #66 on: November 20, 2017, 03:17:14 pm »
All my Sony TVs works great with arcade_15 mode but somehow upper and lower part of screen sometimes are cut so to compesate this I'm using different custom modeline: crt_range0                15625-16200, 49.50-65.00, 2.000, 4.700, 8.000, 0.064, 0.192, 1.424, 0, 0, 192, 288, 448, 576
but try first with arcade_15
folken
« Reply #67 on: November 20, 2017, 06:46:18 pm »
Haynor, I set my Mame.ini monitor line from CUSTOM to arcade_15 with the previous modeline but it results the same (purple and green blurred screen)
haynor666
  • retro maniac
« Reply #68 on: November 21, 2017, 03:11:43 pm »
Don't use any modeline just arcade_15 as monitor
Calamity
  • Moderator
« Reply #69 on: November 21, 2017, 04:36:59 pm »
VMMaker sets "monitor custom" in mame.ini when it exports settings to GM, and edits crt_range lines accordingly. This happens for any monitor preset defined in VMMaker (arcade_15, etc.). This way you can tweak a given preset in VMMaker and then export the modified timings to GM.
folken
« Reply #70 on: November 22, 2017, 10:26:49 am »
Haynor: Ok! ;-)
Calamity: Can you give me an exemple please?
buttersoft
« Reply #71 on: November 22, 2017, 05:46:13 pm »
folken, read the monitor presets sticky at the top of the GM forum. The range line tells VMM and GM the limits of the modelines to generate - the lines min and max are for vertical resolution. When you think you understand a bit more, go into ArcadeOSD, pick a modeline that's messed up, and try increasing the horizontal front and back porches at bit.
folken
« Reply #72 on: November 23, 2017, 03:47:21 pm »
Here are my presets in my Mame.ini: crt_range0  "15625-15750, 49.50-65.00, 2.000, 4.700, 8.000, 0.064, 0.192, 1.024, 0, 0, 192, 288, 448, 576"
And in my VMMaker folder: monitor_specs0 15625-15750, 49.50-65.00, 2.000, 4.700, 8.000, 0.064, 0.192, 1.024, 0, 0, 288, 448
« Last Edit: November 23, 2017, 03:54:40 pm by folken »
buttersoft
« Reply #73 on: November 23, 2017, 07:27:33 pm »
Apologies if you've covered this above, but which OS, GPU, and which crt_emudriver version and VMM version are you using?
folken
« Reply #74 on: November 24, 2017, 04:43:12 am »
My CPU is a Xeon X3380. I have an ATI X300 (X1050) graphic card and 4GB ram. Mame version is 0.158. My OS is XP PRO 64 bits. I will see CRT_Emudriver and VMM versions this afternoon  ;)
haynor666
  • retro maniac
« Reply #75 on: November 24, 2017, 11:13:12 am »
That's a bizarre setup :)
Groovymame was probably never tested with such processor although it should work (I think). But XP x64 was again never designed for Xenon processors. X1050/X300 are old cards that are in theory supported by groovymame but almost abandoned by mame dev, probably You will get message "Your graphics card does not fully support non-power-of-two". Another problem is XP x64 itself discussed - http://forum.arcadecontrols.com/index.php/topic,143085.0.html
Core2 Duo E8500 @ 3.16GHz has almost the same speed for single core.
« Last Edit: November 24, 2017, 11:26:17 am by haynor666 »
folken
« Reply #76 on: November 24, 2017, 11:39:35 am »
Haynor> I remember you told my setup was weird in a previous post :D
How to be sure to have the best and most perfect setup to run all 15Khz games as original hardwares?
I bought the most powerful CPU (Xeon X3380) on this MB with lga775 socket to be sure games will run without any problem... ;)
https://www.cpubenchmark.net/compare.php?cmp[]=1286&cmp[]=5
I bought a new GC (HD 6450-2 GB) ;)
« Last Edit: November 24, 2017, 12:11:07 pm by folken »
haynor666
  • retro maniac
« Reply #77 on: November 24, 2017, 01:28:57 pm »
As I mentioned 2 posts above XP x64 has serious problems with Radeon performance. I ask some people to test this behaviour and by those  people confirmed my problem. Since You have 4 Gb stick with windows 7x64. At some point in time mame might refuse to work not too mention that performance is better and that I also tested but with G3258.
folken
« Reply #78 on: November 24, 2017, 02:18:23 pm »
I will install WINDOWS 7 in the future ;) My CRT_Emudriver version is 1.2b
What do you think about my new GC?
You and Calamity look like to be some experts with GM, CRT_Emudriver, Arcade OSD, VMMaker etc... What is you setup to run 15Khz games?
« Last Edit: November 24, 2017, 04:34:46 pm by folken »
haynor666
  • retro maniac
« Reply #79 on: November 24, 2017, 07:13:29 pm »
I'm not an expert but I've learn how set up groovymame and hardware enough to met my needs :)
My hardware is right now G3258 overclock to 3,8 GHz, 2 Gb RAM (plenty for XP, ok for 7x64) Radeon 5450 (more than enough for mame and old Taito Type X games) plus some cheap 400W Foltron PSU, cheap Asus H87 board and used SSD 128 Gb disk (taken from my main PC) ans some cheap Silentium case.
Your card is more than enough for groovymame.
