Author Topic: Cheaper, simpler, more flexible control board solution - Arduino based  (Read 1485 times)
gschade
  • Last login:August 21, 2017, 05:42:01 pm
Hi all, first post.
Bought a bunch of arcade controls to mess around with off ebay.  I was planning to use a Kade, but the board I ordered was shipping from Singapore or some nonsense and I think I won't get if for a few more weeks.   I had a couple of Arduinos and figured the hardware is basically the same.  So I threw together the following sketch.  Hooked up my joystick and buttons and happilly started playing Donkey Kong and Pitfall!
I actually think this might be better than the $10 zero delay interfaces on ebay (it uses a pretty mature debounce library).  Also, I see no reason you couldn't use this for a trackball, spinner, steering, etc.
I used a leonardo which is why I can use USB;  If you wanted to use a cheaper nano or a UNO, you could use a PS2 interface instead.  You could use a Mega if you needed more pins for more buttons / joysticks (leonardo has 20 pins)
Also there is a joystick library out there for the Leonardo, so you could simulate joysticks easilly.
Anyone have any feedback?  How to make it better?  I am not a pro coder, so I'm sure my code is pretty craptastic, but it gets the job done.
I will update as I try other interfaces.  I have a shifter, Star Wars yoke and a spinner I plan to interface.
Code: [Select]
// Include the Bounce2 library found here :
// https://github.com/thomasfredericks/Bounce-Arduino-Wiring
#include <Bounce2.h>
int upB = 4;   // connect joystick and button controls to pins:  2=right, 3=down, 4=up, 5=left, 6=fire
int downB = 3;   // 2=right, 3=down, 4=up, 5=left, 6=fire
int leftB = 5;   // 2=right, 3=down, 4=up, 5=left, 6=fire
int rightB = 2;   // 2=right, 3=down, 4=up, 5=left, 6=fire
int fireB = 6;   // 2=right, 3=down, 4=up, 5=left, 6=fire
// Instantiate Bounce objects
Bounce debouncerFire = Bounce();
Bounce debouncerUp = Bounce();
Bounce debouncerDown = Bounce();
Bounce debouncerLeft = Bounce();
Bounce debouncerRight = Bounce();
void setup()
  Keyboard.begin();
  // Setup buttons with  internal pull-up :
  pinMode(fireB,INPUT_PULLUP);
  debouncerFire.attach(fireB);
  debouncerFire.interval(5); // interval in ms
  pinMode(upB,INPUT_PULLUP);
  debouncerUp.attach(upB);
  debouncerUp.interval(5); // interval in ms
  pinMode(downB,INPUT_PULLUP);
  debouncerDown.attach(downB);
  debouncerDown.interval(5); // interval in ms
  pinMode(leftB,INPUT_PULLUP);
  debouncerLeft.attach(leftB);
  debouncerLeft.interval(5); // interval in ms
  pinMode(rightB,INPUT_PULLUP);
  debouncerRight.attach(rightB);
  debouncerRight.interval(5); // interval in ms
void loop()
  if (debouncerFire.update()) {
     if (debouncerFire.read()==LOW) {
      Keyboard.press(' ');
      else {
      Keyboard.release(' ');
  if (debouncerRight.update()) {
     if (debouncerRight.read()==LOW) {
      Keyboard.press(KEY_RIGHT_ARROW);
      else {
      Keyboard.release(KEY_RIGHT_ARROW);
  if (debouncerLeft.update()) {
     if (debouncerLeft.read()==LOW) {
      Keyboard.press(KEY_LEFT_ARROW);
      else {
      Keyboard.release(KEY_LEFT_ARROW);
  if (debouncerUp.update()) {
     if (debouncerUp.read()==LOW) {
      Keyboard.press(KEY_UP_ARROW);
      else {
      Keyboard.release(KEY_UP_ARROW);
  if (debouncerDown.update()) {
     if (debouncerDown.read()==LOW) {
      Keyboard.press(KEY_DOWN_ARROW);
      else {
      Keyboard.release(KEY_DOWN_ARROW);
« Last Edit: December 14, 2015, 08:53:05 pm by gschade »
