Author Topic: Is this a good enough monitor for a standard cab?  (Read 1358 times)
Violineb
  • Last login:October 19, 2007, 03:18:15 am
« on: January 11, 2004, 12:35:52 am »
I want to build a cabinet that doesn't cost too much and so I knew I had to choose between a TV or a PC monitor. I got reluctant with the TV choice because of overscan and other issues with the image quality of TV out when I tried on my 27 inch. All I wanted to know is if this is a good or bad price for a 21 inch monitor I found in the newpaper. It's a Viewsonic 21PS.
http://www.monitorworld.com/Monitors/viewsonic/viewsonic21ps.html
Seems that it is pretty old, as they came out in 1996 I think.....for $2000 :o I'm quite sure a 21 inch should do the job as far as size goes, just need to know if $90 is too much. K thanks :)
fredster
  • It's all good!
Re:Is this a good enough monitor for a standard cab?
« Reply #1 on: January 12, 2004, 11:15:06 am »
No, that's okay.  But don't do that.  There are always computer shows at the fairgrounds or conventions centers.  You can pick up a 17" for $20 or a big 20-21" for $75-150 depending on the type.
Go to the computer show and you might find all those goodies for the cab cheap.
