Author Topic: Mala Display  (Read 5396 times)
Cas80
  • Last login:December 21, 2015, 11:30:29 pm
Mala Display
« on: December 07, 2015, 07:06:20 pm »
Please help. Im new to Mala and have no idea what im doin wrong. I cant seem to get Layout to fit to my screen. Also videos wont work. Please help and thank you
big10p
  • Last login:May 01, 2023, 01:46:23 pm
  • Mmmm, arcade classics!
Re: Mala Display
« Reply #1 on: December 08, 2015, 08:15:31 am »
MaLa always runs at whatever resolution your desktop is set to. What res is your desktop and what res is your layout?
I had problems with videos in MaLa until I installed the CCCP codecs:
http://www.cccp-project.net/
Cas80
Re: Mala Display
« Reply #2 on: December 08, 2015, 11:40:38 am »
Thanks for ur help!!!
Screen resultion is 1920x1080
I attached the cab
big10p
Re: Mala Display
« Reply #3 on: December 08, 2015, 12:06:10 pm »
So, you're using a widescreen monitor (16:9 ratio). The layout in that zip is 4:3 ratio, with a resolution of 1024x768, and isn't designed for use on a widescreen display.
If you want to use it, I suggest you load it into the MaLa layout editor and set it to a fixed sized, 1920x1080 layout. Then you will have to reposition and resize the layout elements to fit.
Cas80
Re: Mala Display
« Reply #4 on: December 08, 2015, 12:56:06 pm »
ok cheers.
Installed that cccp file but videos still wont work?
big10p
Re: Mala Display
« Reply #5 on: December 08, 2015, 01:02:20 pm »
Make sure you're using the latest version of MaLa (1.83 beta, I think). Earlier versions don't support mp4 videos, if that's what you're using.
Cas80
Re: Mala Display
« Reply #6 on: December 13, 2015, 06:19:26 am »
Thats what is was. Cheers for that.
Next issue - i generate a rom list in order of year made but when mala shows it its in alphabetical order. How do i make it list by year.
Cheers
