Author Topic: Rome AMI CD-RNH Error code 14-06 Low Battery - HELP  (Read 5086 times)
d0n
  • Last login:November 19, 2017, 01:59:28 pm
« on: December 03, 2015, 08:54:43 pm »
Hi folks I just picked up a nice 1996 rowe ami cd-rnh bubble jukebox. It was in use a few years ago but stopped working due to a single error code.
It has about 17 CDs in it. When I hit any selection it says "NOT ALLOWED'.
I've checked the code and it's 14-06 which equates to "low battery". I cannot find a battery in this jukebox. Where might it be and what kind of battery am I looking for?
Ken Layton
  • Guru
  • Technician
Re: Rome AMI CD-RNH Error code 14-06 Low Battery - HELP
« Reply #1 on: December 03, 2015, 11:30:25 pm »
Battery is attached to the board inside the "Central Control Computer". It's a coin cell type like a CR2032.
d0n
« Reply #2 on: December 04, 2015, 09:59:17 am »
ok great thanks!
Found it. Soldered to the board. br2325
d0n
« Reply #3 on: December 04, 2015, 03:52:53 pm »
Found it, removed it and soldered on a remotely located 2 AA holder that'll make changing the batteries easier in the future.
The only issue with the jukebox is a noticeably loud constant HUMMMM or BZZZZZZZZZ coming from the main power supply. Is this something I can fix? It's quite annoying at lower volumes.
ami-man
  • Last login:July 19, 2020, 01:22:45 pm
« Reply #4 on: December 08, 2015, 11:44:47 am »
Hi d0n,
The battery used as Ken said is a 3 volt battery, you can buy disk battery holders if you wish to have a quick replacement routine.
Regards
Alan
