Author Topic: CNC Cutting services available in Calgary, Alberta  (Read 5288 times)
Cornelsworld
  • Last login:January 16, 2016, 03:01:40 pm
« on: November 30, 2015, 12:37:09 am »
I have a small business in Calgary NE and have recently purchased a CNC Router. I am looking for other projects to keep my router busy. I can do many different types of projects from wood, plastic, aluminum, and foam.
Cutting projects can include arcade cabinets, signage, prototypes, wooden furniture, cabinetry, kids signs/toys and just about anything you can dream up.
Design consultation is available as well as supply of the materials if required. Costs vary depending on complexity and time for design/cutting but cutting starts at $50 per sheet
I have included some of the projects in the pictures below that I have done in the past as a sample of what can be done
I can be contacted by phone or text at (403) 807-0168, or quotes@cornelsworld.com
ChanceKJ
« Reply #1 on: November 30, 2015, 02:43:16 am »
« Last Edit: March 19, 2021, 03:23:21 am by ChanceKJ »
IronStrike
  • Last login:February 06, 2018, 07:32:24 pm
Re: CNC Cutting services available in Calgary, Alberta
« Reply #2 on: March 15, 2016, 11:28:37 am »
Hi Cornelsworld/Greg,
ChanceKJ recommended you! I am also here in Calgary and think you would be my best bet here.
I have 3 projects I would need help with.
  • Building a 4P Arcade Cabinet - I am going to be using ChanceKJ's side Panels, haven't decided on the control panel yet
  • Building a 2P Arcade Cabinet - I can provide the plans
  • I am looking to build a Reverse Geocache for a special project - It is essentially a wooden lock box with a hidden panel and could use something to just test with
Thoughts? I'll also shoot you a text.
