Author Topic: Vertical Adjustment On A Nanao KB240331D/MC2000-S?  (Read 1802 times)
TheBelly
  • Last login:December 01, 2015, 01:06:26 am
« on: November 27, 2015, 12:20:47 am »
Hi All,
Please excuse my ignorance, I am fairly new to the world of arcade machines.
I recently picked up an old arcade cabinet and have got most of the issues sorted out apart from the vertical adjustment on the monitor.  I have installed a Jamma 60 in 1 board which is working fine.  The cabinet has a Nanao KB240331D/MC2000-s chassis which is working but I dare say could do with a cap kit.  I need to reduce the vertical size of the picture but the vertical H pot has a totally different looking pot on it and I am wary about fiddling around with it until I get some guidance.
How do you adjust the vertical height on this type of chassis?  Is there a special little tool required, do you simply put a screwdriver up into the tube or is there no adjustment possible?
Thanks in advance.
grantspain
Re: Vertical Adjustment On A Nanao KB240331D/MC2000-S?
« Reply #1 on: November 27, 2015, 09:18:49 am »
do you mean horizontal size coil,if so you need a plastic hex trim tool
best post a photo of what you talking about
TheBelly
« Reply #2 on: November 28, 2015, 05:42:22 am »
Yep I am pretty sure that sounds right.  It is more of a cylinder which is several cm's long as opposed to the regular white pots for all of the other adjustments.  Now to source one here in Australia.
Thanks very much!
TheBelly
« Reply #3 on: November 29, 2015, 07:46:06 pm »
Anyone have any idea where I could get one of the plastic hex trim tool please?  It would need to be posted to Australia.
Thanks.
  • Last login:Yesterday at 11:20:29 pm
« Reply #4 on: November 29, 2015, 08:46:26 pm »
If Mouser or another electronic supplier doesn't have them, you might be able to 3D-print one like this. (not sure if the size is right  :dunno)
