Author Topic: [APP] Game, Set and Match - Image Sets Manager  (Read 4720 times)
stigzler
    • Mago Arcade
« on: November 09, 2015, 05:27:24 pm »
An application to manage game related image sets. Specifically designed for collaborative efforts via cloud services, but can also be used individually with local folders only. Basically, it parses info from any game .dat/.xml/.db3 files, pulls a specified field for game/image names in your assets folder then presents a GUI to compare and move around images matched to the games between 3 folders
Other Screens:
« Last Edit: May 28, 2016, 01:47:59 pm by stigzler »
Slippyblade
Re: [APP] Game, Set and Match
« Reply #1 on: November 09, 2015, 05:51:29 pm »
Linky?
stigzler
    • Mago Arcade
« Reply #2 on: November 09, 2015, 06:44:43 pm »
Oh yeah... forgot that bit. Amended.
Slippyblade
« Reply #3 on: November 09, 2015, 08:49:40 pm »
Cool, thanks.  Will check this out later.
stigzler
    • Mago Arcade
« Reply #4 on: May 22, 2016, 05:56:35 pm »
Update
1.1.0
Overhaul of Image Matching:
 - Remove bracketed text from Image filename (e.g. "(USA)")
Option to save image (on move from one folder to another) as:
 - Original Filename
 - Database Game Name
 - Database RomName (e.g. as per differetn sets - Goodname, NoIntro, Hyperlist etc)
Fuzzy Search using Levenshtein and simple substring finding. This allows you to find images that the search via the chosen RomName format (e.g. NoInto, GoodName etc) may miss.
 Big speedup of loading db and images
 Choice of what format to save moved images in - The DB Game or filename or as the original filename (in the source folder)
 Defaults to DB GameName format if no DB Filename found
 Any DB Gamenames made filesafe (e.g. ":"s stripped from filenames - replaced with " -")
Vid:
stigzler
    • Mago Arcade
Re: [APP] Game, Set and Match - Image Sets Manager
« Reply #5 on: May 28, 2016, 01:46:13 pm »
Update:
 1.2.0
 Added facilitiy for Hyperlist parsing
 Added faciltiy to remove tags (bracketd text) from Database filenames and Gamenames (only in HS at the moment - not needed in GE?)
 Added open folders buttons to main edit window.
stigzler
    • Mago Arcade
« Reply #6 on: June 05, 2016, 04:11:55 pm »
Major Update:
 1.3.0
 Fixed Select All bug
 Fixed major deal breaker - Other folders not being matched.
 Added setting to show images that also match the gamename.
 Added overide saveas when moving images between folders - allows manual setting of filename (made safe)
  Added open search result images in image editor for editing before putting image set folders
 Added image search preview
 Added save any images as png when moving/adding/copying - produces unified sets of png images
 Added database backup roller - keeps rolling backup over months, weeks, days - limited to 10 files
 Added open logs/chagelog buttons
 Added manual backup and restore of database.
 Added image webserch function!
