Author Topic: help!!! xbox to jamma.  (Read 3522 times)
titanux
  • Last login:January 07, 2004, 06:07:23 pm
« on: January 07, 2004, 05:25:49 pm »
the jamma interface use colours, red,blue,green. I hack the cable pinout like a cable scart (15 hz), but the green colour is gray. The red colour is goog, the blue to.  please help me.
DarkKobold
  • Last login:June 18, 2013, 11:31:23 pm
Re:help!!! xbox to jamma.
« Reply #1 on: January 07, 2004, 05:47:54 pm »
If you are trying to use the component video, it won't work. There is extra information included in component video sent.
My games: Tapper, Asteroids, Cocktail-MAME, Tron, ROTJ, Tempest, Star Wars (not working)
My wants: Warlords Cocktail
titanux
« Reply #2 on: January 07, 2004, 05:55:44 pm »
how can do it?
titanux
« Reply #3 on: January 07, 2004, 06:08:44 pm »
 i need use hsync and vsync to get best video? ???
Dave_K.
  • Last login:July 06, 2022, 03:27:30 pm
    • Arcade Fever
« Reply #4 on: January 08, 2004, 02:05:10 am »
If you want RGB you will need to hack an xbox SCART cable.  As DarkKobold pointed out, it sounds like hacked an HD-pack (component) cable (I can see how you might be confused as the Y, Pr and Pb wires are also red/green/blue).  Component or RGB has the best output.  Of course you need a component capable TV to view it (at 480p).  Or you can buy a Component-to-RGB transcoder to send to an RGB monitor (at either 15khz or 31khz).
Read the Game Consoles FAQ on this site for more.
http://www.arcadecontrols.com/arcade_consoles.shtml
BombProofPlane
  • Last login:February 11, 2009, 04:14:14 pm
« Reply #5 on: January 10, 2004, 09:07:36 pm »
actually rgb at 15 khz is already there just no sync
your grounding the wrong connections.
heres the pinout
http://www.gamesx.com/avpinouts/xbox.htm
your gonna need to remove the sync out of the the composite video wire
