Author Topic: Assetto Corsa from Steam on arcade cab?  (Read 2266 times)
flash951
  • Last login:May 18, 2016, 04:22:39 pm
  • You should use CRT display
    • remimedia
« on: October 02, 2015, 04:10:27 pm »
I've purchased Assetto Corsa from Steam. Is it easy to copy it to my Arcade cab PC and play it offline?
Seems possible, only have to be online first to prepare everything.
https://support.steampowered.com/kb_article.php?ref=3160-agcb-2555
« Last Edit: October 02, 2015, 04:16:26 pm by BadMouth »
  • Moderator
  • Last login:Today at 09:24:18 am
Re: Assetto Corsa from Steam on arcade cab?
« Reply #1 on: October 02, 2015, 04:15:23 pm »
(I split this out from the "What to play on your setup" sticky)
See this thread here about how to get steam games working on your cab:
http://forum.arcadecontrols.com/index.php/topic,147216.msg1532383.html#msg1532383
My cab is connected to the internet.
You'll probably at least need to connect the cab to the internet temporarily and then put steam in offline mode.
« Last Edit: October 02, 2015, 04:19:07 pm by BadMouth »
