Author Topic: Having troubles with cut and paste of mame folder  (Read 3401 times)
Delicious
  • Last login:November 22, 2021, 07:11:00 pm
  • I want to learn all i can :)
« on: September 29, 2015, 07:18:58 pm »
Hello all
hopefully someone will know whats wrong,  I have mame on my laptop and everything runs great.  i recently got a desktop that i want to put mame on so i cut and paste my entire mame folder.  nothing works and i dont know why :dunno  my laptop has win8 and the desktop i have transfered to runs win7. could this be a problem?  im using mame version 0.153
also i used an external hd to transfer everything.
any tips or suggestions will be greatly appreciated.
thanks
05SRT4
  • Check out my Pow Pow
Re: Having troubles with cut and paste of mame folder
« Reply #1 on: September 29, 2015, 07:31:11 pm »
Are you opening MAME directly or through a front end?
Slippyblade
« Reply #2 on: September 29, 2015, 07:33:07 pm »
Sounds like a path issue.  MAME does copy/paste with no problems.
Delicious
« Reply #3 on: September 29, 2015, 08:07:01 pm »
ive tried opening it directly.  Ive also tried through MA
Slippyblade
« Reply #4 on: September 29, 2015, 08:13:51 pm »
Ok then.  What, exactly, errors did you get?
Delicious
« Reply #5 on: September 29, 2015, 08:22:39 pm »
Black screen, no content at all.  its like mame is blank.  screen goes totally black till i hit the esc key.  i tried changing the path of the launch path but it does no good so i put it back the way it was.
Slippyblade
« Reply #6 on: September 29, 2015, 08:26:16 pm »
Oh, then it's working.  I'd bet that the previous computer had discreet video and the new one doesn't.  Try this.
mame [rom] -video gdi
 or
mame [rom] -video draw
Lemme know what that does.
« Last Edit: September 29, 2015, 08:28:34 pm by Slippyblade »
Delicious
« Reply #7 on: September 29, 2015, 08:28:20 pm »
where do i type that in the launch bat?  sorry im new to all this and am tinkering with it
Slippyblade
« Reply #8 on: September 29, 2015, 08:33:37 pm »
Do it at the command line.  open up your MAME folder and then hold down the 'Shift' key and right click a blank area in the folder listing.  Choose 'Open Command Window Here'.  Once you do that you will get a small black window with text - that is the command line.  You will replace the [rom] tag with the actual rom name.  dkong or whatever.
Delicious
« Reply #9 on: September 29, 2015, 08:39:04 pm »
 :notworthy:  loaded donkey kong instantly  :applaud: :applaud: :applaud: :applaud: :applaud: :applaud: :applaud:
how do i permanently turn off the discreet video
Slippyblade
« Reply #10 on: September 29, 2015, 08:42:30 pm »
which tag did you use the ddraw or the gdi?  ddraw is much better than gdi, try em both and and see which looks better.  Do you use a front end of any kind?
Delicious
« Reply #11 on: September 29, 2015, 08:44:10 pm »
i used gdi and i did notice it looks a little different kinda pixelated if you will.  i will try the other. and as of right now im doing this without the frontend.  but i plan on using maximus arcade.
Slippyblade
« Reply #12 on: September 29, 2015, 08:50:24 pm »
I've not used Maximus so I can't tell you exactly what to do, but every front end has a place where you tell it the command line to use.  Your instructions will tell you to type "mame" in that spot.  Instead you would just type "mame -video ddraw" in the same spot.  mame doesn't care which comes first, rom or flags, it still works.
Delicious
« Reply #13 on: September 29, 2015, 08:59:08 pm »
gotcha, ill tinker with it and find it.  ive seen where you can add command lines and such.  one other question, Ive noticed that moonwalker doesnt run like it did on my laptop its a little slow.  this pc im using is a dual core 2.4 ghz with 3gig of ram so i would think it shouldnt run like that any ideas on that?
Slippyblade
« Reply #14 on: September 29, 2015, 09:04:53 pm »
If you are using the gdi it's gonna be hella slow.  GDI is using Windows system calls to draw everything.  Using the ddraw flag will be way better but, in my experience, kinda fuzzy.
To see your speed, when the game is running hit F11 - you will get a display in the upper right corner showing you your FPS and the target speed in percents.
Honestly the best thing you can do is spend $30 and get almost ANY cheap dedicated video card for the desktop. That will solve your entire problem.
Delicious
« Reply #15 on: September 29, 2015, 09:08:43 pm »
any reccomendations on a cheap video card? the audio glitched a little too, is that a part of this as well?
Slippyblade
« Reply #16 on: September 29, 2015, 09:22:04 pm »
No clue about audio and I've been out of the loop WAY to long to recommend any cards, sorry.  I'd go through your task manager though and see if anything else is running that might be hogging resources - what you've got should be plenty powerful enough.
Delicious
« Reply #17 on: September 29, 2015, 09:25:21 pm »
 :notworthy:thank you so much for all your help.  I would totally buy you a case of beer if i could.  you have saved me several days of frustration :notworthy:
Slippyblade
« Reply #18 on: September 29, 2015, 09:32:45 pm »
Good luck!
jonnylbluejeans
  • Last login:November 29, 2018, 09:04:28 pm
« Reply #19 on: October 02, 2015, 06:44:43 am »
The audio can glitch if the video render is delayed.  The video card will depend on what type of card slot you have available in your PC.
Delicious
« Reply #20 on: October 03, 2015, 11:30:34 pm »
thanks man, i just ordered a video card for $30 on ebay.  Ill give you all an update on everything as soon as i get it installed. probably monday or tues 8)
Delicious
« Reply #21 on: October 05, 2015, 09:47:55 pm »
Got the video card in today.  installed it and it definately fixed the glitching on moonwalker  :cheers:  only problem is it doesnt quite fit right.  the heat sink is so big that its actually sitting on a couple of electrolytic capacitors.  it almost goes in but not quite,  the giant heatsink also inhibits me from putting the harddrive back in place.
im thinking about taking my dremel and cutting out a clearing for those caps, cause i know that cant be good for the heatsink to be sitting on it.  any suggests or advice definately appreciated.
ive included pics to show my dilemma.
in the second pic that little blue tab is supposed to snap in place but is thus prevented because of the caps
« Last Edit: October 05, 2015, 09:49:44 pm by Delicious »
JDFan
« Reply #22 on: October 05, 2015, 10:41:19 pm »
Looks like it should be a pretty easy fix with the dremel - figure there will still be plenty of heatsink left afterwards so shouldn't create any problems.  :cheers:
