Author Topic: [Solved] Why I can't get rid of nag screens even with the right .INI?  (Read 3211 times)
K-rnivoro
  • Last login:May 03, 2020, 11:51:55 am
I can't understand why even using this commands, I still have nag screens: Warning (yellow screen) and the blue (Switchres) screen.
Command in the mame.ini file:
skip_ gameinfo 1
disable_nagscreen_patch 0
disable_loading_patch 0
Using GM 0.160
« Last Edit: October 09, 2015, 06:18:07 pm by K-rnivoro »
vwalbridge
Re: Why I can't get rid of nag screens even with the right .INI?
« Reply #1 on: September 25, 2015, 11:15:49 am »
Have you seen this thread?
You need to compile your own version of Mame.
K-rnivoro
« Reply #2 on: September 25, 2015, 11:22:21 am »
Thanks vwalbridge. Actually I was about to delete my post because it was a stupid mistake. Running GM directly worked OK, but not from HyperSpin frontend. Turns HyperSpin was pointing to another MAME folder (with diferent .ini file...)
So, I guess there is no need to recompile for the nag screens.
Thanks again.
vwalbridge
« Reply #3 on: September 25, 2015, 11:31:59 am »
Cool. Thanks for posting you solution. No matter how simple, it's always good to close the loop so people can see what worked.
