Author Topic: Do they make a vga inline picture adjuster?  (Read 1722 times)
800screws
  • Last login:November 10, 2019, 07:37:29 am
« on: September 15, 2015, 02:20:20 pm »
Looking for something that can adjust the picture size with a vga signal.  Move it up/down left/right and its position on the screen/ stretching....is there such a thing
Like the options a cga to vga board has.  Only for vga into the monitor.
Re: Do they make a vga inline picture adjuster?
« Reply #1 on: September 15, 2015, 02:37:43 pm »
I know this is a silly suggestion (since I know what youre using this for) but why not use a signal converter from the atomiswave to VGA then use the converter to adjust the pic?
800screws
« Reply #2 on: September 15, 2015, 03:45:15 pm »
The converter just won't work with the signal from the atomiswave.  That was my original plan but it's a no go so im looking for another device hopefully
Paradroid
  • Last login:December 05, 2025, 10:28:19 pm
    • SCART Hunter
« Reply #3 on: September 15, 2015, 04:15:49 pm »
Many of the Extron RGB processors have controls for horizontal and vertical centering. I have the Extron RGB 201 Rxi and it works very well for this. It has a VGA input and BNC outputs.
As for adjusting the size, I can't imagine there will be a solution that doesn't mangle your video signal and introduce all sorts of scaling artifacts. Better to adjust the the H and V directly size on your display if you care about image quality. Less convenient but a better result.
My MAME/SCART/CRT blog: SCART Hunter
800screws
« Reply #4 on: September 17, 2015, 06:39:19 pm »
just checking though...with the  Extron RGB 201 Rxi , does it have vga outputs also? Im not seeing that? or is that where it says remote?
