Author Topic: Lowboy Cabaret  (Read 13693 times)
jan25th
  • Last login:September 11, 2025, 10:15:20 am
  • Long time lurker
    • forum.arcadecontrols.com/index.php/topic,147244.0.html
Re: Lowboy Cabaret
« Reply #40 on: June 25, 2016, 03:33:56 pm »
Thanks for the kind words all, am really feeling the love. :cheers:
@markc74 I am not overly artistic so thought I was planning to modify the Dig Dug sideart to fit my profile. I am not in love with the Dig Dug control panel art though so I may take some artistic license there - I know it's sacrilege. I never really thought about Taito but I do see some resemblance, but I am not smitten with that design either.
I had never seen a lowboy until a few years and in this forum. I think it suits me better because it looks less imposing and I am hoping to sneak a second horizontal monitor cab down the road. Shhh, don't tell my wife.
jan25th
  • Long time lurker
Test fitting speaker grills
« Reply #41 on: June 25, 2016, 05:07:39 pm »
Test fitting the speaker grills in the speaker panel
jan25th
  • Long time lurker
Re: Lowboy Cabaret
« Reply #42 on: June 25, 2016, 05:09:58 pm »
For marquee retainers I am using 3/4” x 1/2” aluminum 90 degree angles that I picked up from Home Depot. I actually thought both legs were 3/4” but this should be fine as well.
In my original plans the angles for the marquee retainers would be <90 for the top and >90 for the bottom.
I don’t have a metal brake so played with clamping one leg of my al retainers and bending using a hardwood block. That was a fail. I eventually gave up trying to bend it and ended up modifying the cabinet top to make that a 90 degree angle but Ihe bottom remains about 102 degrees.
To make the bottom retainer fit squarely I have cut a bevel in the speaker panel
Now the bottom retainer  will sit squarely:
« Last Edit: June 25, 2016, 05:37:48 pm by jan25th »
jan25th
  • Long time lurker
Speaker panel installation
« Reply #43 on: June 25, 2016, 06:21:09 pm »
I have been experimenting with the speaker panel. I am not certain how good the speakers are (yes I could hook them up and test them), the speaker board is actually around 3/16” to narrow, and I wasn’t certain how the bottom marquee retainer would fit. Because of this I have chosen to not permanently attach the panel to the cab. For now I have used 4 metal braces that will allow me easily replace it later.
Speaker panel mounted with one speaker grill. I had removed the grills from my earlier picture wanted to get a picture of the panel installed with a grill so I reinserted one. As the grills are a pretty tight fit, each time I insert and remove them it damages the plywood edge, so I won’t be fitting the grills again until I finish this panel and paint it.
jan25th
  • Long time lurker
Marquee
« Reply #44 on: June 25, 2016, 10:24:17 pm »
For the marquee lighting I picked up an Ikea Dioder a while ago.
seemed like a good idea at the time, although now I wish I patronized one of the the forum vendors that supplies purpose built lighting.
I have cut a piece of 1/2” plywood and mounted the lights to it.
And with it placed in the marquee area
It is blindingly bright and doesn’t photograph well.
With my laser printed marquee and lit.
lettuce
  • Make It So!
Re: Lowboy Cabaret
« Reply #45 on: July 03, 2016, 06:14:37 am »
Great Project....reminds me i need to get back to my lowboy at some pont  :-[....
http://forum.arcadecontrols.com/index.php?topic=128309.msg1316724#msg1316724
or though i think i might go for a Jaleco Pony III shape now
tomstewdevine
    • A Comic Book Look
Re: Lowboy Cabaret
« Reply #46 on: July 05, 2016, 12:13:43 pm »
Really cool project, thanks for the good pictures.
jan25th
  • Long time lurker
Priming
« Reply #47 on: July 19, 2016, 01:26:45 pm »
Am getting back to this after a few weeks vacation. Spent July 1 in Vancouver BC and saw 20 minutes of fireworks. Then went to Portland for a wedding on July 4 and saw more fireworks, but this time I stopped watching after 30 minutes while the fireworks went on for at least 3 more hours - could have been longer but I eventually fell asleep. Crazy yanks.
Am priming the cabinet now. I purchased Sherwin Williams alkyd paint with a good roller and so far am very happy with the results. Not too much to see at this point except my messy basement, but here is something for you.
jan25th
  • Long time lurker
Re: Lowboy Cabaret
« Reply #48 on: August 31, 2016, 04:10:55 pm »
I have created a post in Artwork re my -- artwork --.  Please see http://forum.arcadecontrols.com/index.php/topic,151557.0.html
