Author Topic: sanwa joystick mounting depth  (Read 2242 times)
Ocoro
  • Last login:September 05, 2015, 04:04:36 pm
« on: September 05, 2015, 08:15:06 am »
hi
I've made a 16mm thick wooden panel with my layout and I've read that the standard is about 24mm of the joystick showing through + the balltop. this way I only have 16.5mm(sanwa jlf with standard mounting plate). the wood is pretty strong but I'm still not sure whether I should cut it. does anybody here use a lower mounted joystick? what would you guys recommend I do?
thanks
  • Last login:Today at 08:31:53 pm
Re: sanwa joystick mounting depth
« Reply #1 on: September 05, 2015, 02:56:44 pm »
Welcome aboard, Ocoro.   ;D
1. Check out this part of the FAQ for joystick mounting methods.
2. Make a test panel. (step 9 here)  That's the only way to know for sure what you will like.
Ocoro
« Reply #2 on: September 05, 2015, 04:04:50 pm »
I've already drilled all the holes, I'm just curious if anybody has played with a lower joystick and if they'd recommend it. This is actually my first arcade stick and I'm not exactly sure what'd be right or comfortable for let's say 1-2 hours of usage at a time. I might just end up mounting it like this and if it's no good I'll put it higher
thanks
keilmillerjr
  • Web Developer.
« Reply #3 on: September 05, 2015, 08:05:42 pm »
thanks
I don't know if I have enough quarters for 2 hours of use.
