Author Topic: Monitor shows noise when plugging PC (no turning it on, just plugging).  (Read 1206 times)
buttheadrulesagain
  • Last login:September 04, 2015, 02:32:41 pm
Hello! I am setting up a new PC in my arcade cabinet, but the monitor shows a lot of noise when I plug this new PC to the power outlet (not even turning the PC on). The old PC I had in the cabinet before doesn't have this problem.
Observations: Sometimes the new PC will turn off after seconds of turning on, I have to unplug, plug and try again. Sometimes several times. I tried taking out the mobo and the power source, and placing them on a non-conductive surface, but it still shows noise.
Any input will be greatly appreciated.
« Last Edit: September 03, 2015, 05:12:27 pm by buttheadrulesagain »
buttheadrulesagain
Re: Monitor shows noise when plugging PC (no turning it on, just plugging).
« Reply #1 on: September 03, 2015, 12:48:49 pm »
m.andrade1
  • Last login:April 10, 2025, 09:05:35 am
« Reply #2 on: September 03, 2015, 02:39:30 pm »
Hello buttheadrulesagain
I had the same issue with my mame cab, the power supply from the new pc was a crappy 200w one, i change for a Corsair 430cx, and the picture on the tube is noise free completely, another thing i did before that, was check if ground was properly attached to the computer (3 pin cable) and the chassi arcade monitor too, those 2 steps clear the image completely!
buttheadrulesagain
« Reply #3 on: September 03, 2015, 05:11:56 pm »
I will totally check on those two things, thanks mate!
