Author Topic: Is there a way to have a vertical theme that works when windows vertical  (Read 6201 times)
monkeybomb
  • PM me to find out how to get a custom title like mine!
  • Last login:January 03, 2018, 07:16:29 pm
I am trying to come up with a vertical theme that doesn't assume I am going to rotate the monitor without rotating the OS.  If I click vertical in MALA or a MALA theme in attract mode FE, then the theme turns 90 degrees even though it's already turned. By simply changing the windows display setting from landscape top portrait, everything is vertical including MAME games and MAME GUI.
  • Last login:Yesterday at 08:14:47 am
Re: Is there a way to have a vertical theme that works when windows vertical
« Reply #1 on: September 02, 2015, 04:52:41 pm »
Why would you rotate the windows desktop?
MAME displays the games vertically just fine without rotating windows.
The front-end displays a vertical version just fine without rotating windows.
vwalbridge
« Reply #2 on: September 02, 2015, 05:10:33 pm »
+1    This is how Hyperspin does it too.
monkeybomb
« Reply #3 on: September 02, 2015, 09:33:04 pm »
To each his own there.  You probably did a better job getting everything set up before mounting the monitor.  I had a party last Saturday and rushed to get the cabinet together, even without a pretty front end.  So if I leave the front end to use the options menu of the FE or encoder or windows, the screen is sideways.  The mouse is easier to use as well.  The solution is just to rotate when I need to and go right back.  When the cabinet is totally set up this shouldn't need to happen anyway.
For me, MAME displays the game correctly when windows is rotated 90 degrees, but it displays sideways when all I do is rotate the monitor. I couldn't figure out how to set video defaults from the in game menu like you can for the controls and changing each game one at a time was a poor solution. But I remembered I could set the rotation as the default in MAMEUI64.  I forgot I could do that. I also still want to call it mame 32, but time does march on.
Correct, but because the themes are created sideways and we can set MAME to run sideways as well.  IMO simply rotating the whole computer with 2 clicks on the desktop is easier.   I haven't tried vectrex yet.  I hope it rotates like mame does.
But of this is a big deal, after I was able to set the default video option in MAME 32 Mameui64.
As for Hyperspin, I never did find Jeepguy80's cocktail set on the main site or the ftp site.  It's not a choice in the cool new sync system either.  On a different note, I did disable the animated joystick and blinky "free play" on my horizontal HS setup.  I like HS way better than I did before you told me I could get rid of those.  Thank you on that one for sure.
raph
  • Last login:May 25, 2024, 03:21:37 am
  • Gradually adding bells and whistles to a stock cab
« Reply #4 on: September 03, 2015, 12:57:32 am »
ParaJVE has rotation options like MAME.
jaharr01
« Reply #5 on: September 04, 2015, 10:34:41 am »
What I did was set up a horizontal theme in Mala in the resolution of my portrait mode like 920x1280 works fine that way
Jay
