Hello,
I have used GroovyMame many times on 15khz monitors and it has worked great. But now the cab I'm using (Naomi Univeral) has a VGA only monitor which I am currently running Vert for Shmups.
What settings should I be using in the .ini file for 31khz display to get the best scrolling, as I know the resolution options are limited.
Also I am currently using an Nvidia gtx 550 with soft15k installed using only the 31khz option and Windows 7.
I am not sure if I want to change out to an ATI card and the custom drivers if it isn't going to make much of a difference.
