Author Topic: Mame Aspect Ratio  (Read 6436 times)
Ledsigns80
  • Last login:November 07, 2017, 09:42:16 am
Mame Aspect Ratio
« on: August 27, 2015, 03:34:01 pm »
I was finally able to get Mame up and running using mGalaxy to my liking :applaud:  Anyway wanted to know if there was a way for mame to launch in a 16:9 format or better put for the 4:3 game screen stretched across a 16:9 monitor.   I know it may not look the best but was just curious.
  • Last login:Yesterday at 08:32:45 pm
Re: Mame Aspect Ratio
« Reply #1 on: August 27, 2015, 03:40:29 pm »
You really want to do this?
Haze
    • MAME Development Blog
« Reply #2 on: August 27, 2015, 03:45:23 pm »
it's dumb, but yeah, it's the most common thing I get asked about MAME IRL, people can't stand black bars and would rather have the game stretched full width, even vertical shooters like DoDonPachi... it's sacrilege, but there yo go..
« Reply #3 on: August 27, 2015, 03:48:10 pm »
Just use bezel artwork to fill the black spaces.  :dunno
monkeybomb
  • PM me to find out how to get a custom title like mine!
  • Last login:January 03, 2018, 07:16:29 pm
« Reply #4 on: August 27, 2015, 04:06:31 pm »
Honestly, I would just play the bad retro ports on xbox live before going through the trouble of setting up something with arcade controls, if the final product is that distorted.  Or even a jaks plug and play on an old 13" TV.  There's lots of 19" TVs on craigslist for $10.  VGA to RCA converters are also cheap at this point.  Yotsuya's suggestion is a good one if you really are stuck with the 16:9 monitor.  I'd even go with a posterboard cut to the right size, as a bezel, before ruining the game.
Ledsigns80
« Reply #5 on: August 27, 2015, 07:00:19 pm »
I like that idea a lot actually is there a how to on how to do that???i wonder if Mgalaxy supports it?
big10p
  • Last login:May 01, 2023, 01:46:23 pm
  • Mmmm, arcade classics!
« Reply #6 on: August 27, 2015, 07:28:29 pm »
You may like to look at my widescreen artwork packs:
http://www.mameworld.info/ubbthreads/showthreaded.php?Cat=&Number=324578&page=0&view=expanded&sb=5&o=&fpart=1&vc=1
lamprey
« Reply #7 on: August 28, 2015, 11:43:19 am »
Six posts and not a single anwer to your question, weird. Someone maybe able to give you better specific directions, but I'm not on a computer that has MAME nor do I do this, but I think you need to change two things in the INI file:
keepaspect                0
and I think you also need to set the aspect:
aspect                    16:9
There is also HWSTRETCH, I don't know if that needs to be adjusted or not.
woosdom
  • Last login:June 13, 2025, 06:14:45 pm
Mame Aspect Ratio
« Reply #8 on: August 29, 2015, 07:28:17 pm »
that doesn't have to happen if you use horizont.ini and vertical.ini
keep aspect on the vertical.ini
but bezels are the way  to go
« Reply #9 on: August 29, 2015, 08:14:42 pm »
That was a hypothetical.  But still,  if you're gonna stretch the horizontal,  you'd probably be the type to stretch the vertical as well.
Bezels rule.
woosdom
« Reply #10 on: September 02, 2015, 09:07:20 pm »
yep. I stretched out the horizontal games on my living room setup and left the verticals with bezels.  don't mind them stretched but the vert games just look way too funky.  any other setup I use the bezels when using widescreen
