Author Topic: Boot problem after hdd install  (Read 1655 times)
axys
  • Last login:August 28, 2015, 01:07:03 pm
« on: August 27, 2015, 06:20:22 am »
Hello,
I'm trying to install GroovyArcade-Arch2015.02.15-x86_64, from an usb key, following this tutorial: https://code.google.com/p/groovyarcade/wiki/GroovyArcade_Install_Config_Guide.
During the install, I delete all partitions of the hdd, then auto install.
The problem is that after the reboot, the pc won't boot: "Insert valid boot drive..."
I suspect an UEFI problem (legacy/UEFI is enabled (instead of UEFI)). I have installed a Debian distribution without problem.
Any idea about this problem ?
Sorry about my bad English  :-[
axys
Re: Boot problem after hdd install
« Reply #1 on: August 28, 2015, 12:21:05 pm »
After many tries, the problem is the motherboard. The UEFI is very bugged.
I found an USB key compatible with the board. Auto install works well with it.  :D
Thanks for the distrib.
