Author Topic: Donkey Kong Replica: Scratch build using Gaetan's plans - 95% done  (Read 132953 times)
ChanceKJ
« Reply #240 on: December 03, 2015, 05:05:10 pm »
« Last Edit: March 19, 2021, 03:33:08 am by ChanceKJ »
  • Last login:Today at 04:15:32 pm
Re: Donkey Kong Replica: Scratch build using Gaetan's plans
« Reply #241 on: December 03, 2015, 05:19:28 pm »
How's the DK sounds on that 60-in-1?  If I remember correctly, those boards have some crummy sound emulation for certain games, I think due to some older version of mame they hacked together for these.
I've only messed around with a 60-in-1 once before, but I vaguely remember DK, DK jr. and 1942 having some really scratchy audio.
johnrt
« Reply #242 on: December 03, 2015, 05:29:37 pm »
You are right. The sound is crap!
Well, It might not stay in there for long.
« Last Edit: March 04, 2016, 09:26:38 pm by johnrt »
vwalbridge
« Reply #243 on: December 03, 2015, 05:31:45 pm »
What I received was this. 100 of them!  :lol
Why can't this happen to me when I order something like a PS4?
« Reply #244 on: December 03, 2015, 05:35:26 pm »
What are you going to do with 100 PS4's?? :lol  (aside the obvious selling of them)
« Reply #245 on: December 03, 2015, 05:45:41 pm »
That's what's cool about you wiring it for Jamma. You can easily swap it out later. The ArcadeSD is pricey but it is a much better option.
ChanceKJ
« Reply #246 on: December 03, 2015, 05:56:35 pm »
« Last Edit: March 19, 2021, 03:32:55 am by ChanceKJ »
vwalbridge
« Reply #247 on: December 03, 2015, 06:09:34 pm »
2 dumb Questions about the Arcade SD:
1. I assume you need a scan line generator for the authentic look if you are using an LCD?
2. I'm confused how you play horizontal games on a vertical monitor and vise versa? Is the menu system rotated 90 degrees all the time if you catch my drift?
ChanceKJ
« Reply #248 on: December 03, 2015, 06:24:23 pm »
« Last Edit: March 19, 2021, 03:32:39 am by ChanceKJ »
johnrt
« Reply #249 on: December 05, 2015, 07:14:09 am »
3rd dumd question about the ArcadeSD: does it come in blue? No, can you connect it directly to a jamma cab without doing anything video-wise?
« Last Edit: March 04, 2016, 09:26:51 pm by johnrt »
ChanceKJ
« Reply #250 on: December 06, 2015, 09:02:15 pm »
« Last Edit: March 19, 2021, 03:28:24 am by ChanceKJ »
johnrt
« Reply #251 on: December 10, 2015, 03:55:51 pm »
So today I made the SCART-RGB cable. I'm very satisfied with this one. It looks like it's just came out of the SCART-RGB factory.
And it works!
So now I have to figure out how the hell I'm gonna mount that TV.  :dizzy:
« Last Edit: March 04, 2016, 09:26:59 pm by johnrt »
ChanceKJ
« Reply #252 on: December 10, 2015, 08:57:50 pm »
« Last Edit: March 19, 2021, 03:27:06 am by ChanceKJ »
johnrt
« Reply #253 on: December 11, 2015, 08:17:00 am »
Decase it :)
Of course. And then what?
« Last Edit: March 04, 2016, 09:27:07 pm by johnrt »
vwalbridge
« Reply #254 on: December 11, 2015, 09:28:27 am »
Decase it :)
Couple globs of hot glue should hold her down.
...just kidding, I have no idea how your mounting that thing.  :)
ChanceKJ
« Reply #255 on: December 11, 2015, 10:30:36 am »
« Last Edit: March 19, 2021, 03:22:57 am by ChanceKJ »
« Reply #256 on: December 11, 2015, 10:48:43 am »
I have a method. Once I get to a computer I will search the topics where I posted it.
« Reply #257 on: December 11, 2015, 11:48:20 am »
I think I mentioned it earlier in this thread but here it is again (this time with link and pics):
I mounted a 19" de-cased PC CRT monitor in one of my cabs and it was easy using the method below.  I didn't bother with a frame although I did use the existing brackets in the machine (mine were made of wood but you could also use metal ones that are in the machine already).
I simply de-cased the monitor and attached this electrical gang box cover (90 cents at Lowes or Home Depot) to the monitor bolts on all 4 corners.
Then you simply rotate the covers to line up with the existing holes on the brackets and drill a hole for each.  Solid fit without the fuss and cheap as all heck.
You can do the same with a TV which should have the same 4 bolts.
DeLuSioNaL29
ChanceKJ
« Reply #258 on: December 11, 2015, 03:03:40 pm »
« Last Edit: March 19, 2021, 03:22:41 am by ChanceKJ »
johnrt
« Reply #259 on: December 11, 2015, 04:25:25 pm »
Thanks! So what about the chassis? How did you mount that? Just screwed it to a shelf or the side of the cab?
« Last Edit: March 04, 2016, 09:27:23 pm by johnrt »
« Reply #260 on: December 11, 2015, 10:14:15 pm »
When you decase it, just the front and back come off. The chassis should remain intact to some sort of frame.
johnrt
Re: Donkey Kong Replica: Scratch build using Gaetan's plans - Need measurements
« Reply #261 on: December 14, 2015, 08:36:05 am »
I need some measurements, please. Can somebody measure the red, blue and green lines on this pic: Please???  :notworthy:
I know they wont be exact, but it would help nevertheless.
« Last Edit: March 04, 2016, 09:27:31 pm by johnrt »
ChanceKJ
« Reply #262 on: December 14, 2015, 09:35:26 am »
« Last Edit: March 19, 2021, 03:22:18 am by ChanceKJ »
johnrt
« Reply #263 on: December 14, 2015, 09:36:58 am »
These measurements are taken from the centre of the monitor, not the corners of the tube. They are approximate.
Green: 9 inches
Red: 20.25 inches
Thanks! What about the blue one?
Ohh... never mind! :-P
yamatetsu
  • Last login:Yesterday at 04:42:12 pm
  • Just because.
« Reply #264 on: December 14, 2015, 09:58:35 am »
I took the pic into a graphics program, enlarged it proportionally and drew the three lines. According to the program,
green is about 210 mm, red is about 518 mm and blue is about 62 mm.
Locke141
  • Never grow up.
« Reply #265 on: December 14, 2015, 10:39:14 am »
This is such a nice build. :applaud:
I'm Jealous you get to use a SCART TV. I had an opportunity to pick one up when I was living in Tanzania. Even ordered a SCART to VGA cable off eBay. Had a bit of a time crunch, was moving to Nepal, and I did not get it before the movers came.  :-[
My understanding is if that a SCART tv is functionally identical to a real arcade monitor. You may want to try trading out the 60-1 for Groovy Mame on an old PC. You would need to get an ATI graphics card but a cheep old one should do fine, if all the research I did is correct.
« Last Edit: December 14, 2015, 10:45:29 am by Locke141 »
johnrt
« Reply #266 on: December 14, 2015, 10:42:47 am »
You may want to use Groovy Mame on an old PC. You would need to get an ATI graphics card but a cheep old should do fine if all the research I did is correct.
Nope! This will be JAMMA only. Eventually I'll get hold of an ArcadeSD, but for now it's a 60-in-1 with ONE game enabled.
« Last Edit: March 04, 2016, 09:27:44 pm by johnrt »
ChanceKJ
« Reply #267 on: December 14, 2015, 11:01:07 am »
« Last Edit: March 19, 2021, 03:22:06 am by ChanceKJ »
johnrt
« Reply #268 on: December 14, 2015, 11:04:25 am »
...but for now it's a 60-in-1 with ONE game enabled.
PacMan?
Yeah, right! I find the 60-in-1 so crappy. I'm so glad I ordered it during chinese black friday. I paid next to nothing for the damn ---steaming pile of meadow muffin---.
« Last Edit: March 04, 2016, 09:27:54 pm by johnrt »
Locke141
  • Never grow up.
« Reply #269 on: December 14, 2015, 11:14:01 am »
You might be able to use a J-pac ($59 US) with an old PC (often free) running Groovy MAME (Free)... I think? I don't have a J-pac and Like I said, my plans to use SCART fell apart. It may be worth looking into and would probably be cheeper then an arcade SD ($325 US).  :dunno
I ordered a Pandras box 3 kit on 11.11 (Chines black Friday). It has not arrived yet, but am hoping it doesn't suck to much. It was cheep and I wanted to give a xxx-1 a try.
« Last Edit: December 14, 2015, 11:29:23 am by Locke141 »
  • Last login:Yesterday at 11:23:23 pm
« Reply #270 on: December 14, 2015, 12:18:06 pm »
Many TVs and PC monitors don't have the same frame as an arcade monitor because they weren't intended to be decased. Just FYI.
johnrt
« Reply #271 on: December 14, 2015, 12:53:17 pm »
And this is the case for most "modern" CRT TV's. Also for mine. There isn't any frame. I'll figure out something.
« Last Edit: March 04, 2016, 09:28:03 pm by johnrt »
« Reply #272 on: December 14, 2015, 01:01:34 pm »
I fashioned one out of metal. And another from wood.
ChanceKJ
« Reply #273 on: December 14, 2015, 02:49:55 pm »
« Last Edit: March 19, 2021, 03:21:55 am by ChanceKJ »
johnrt
« Reply #274 on: December 14, 2015, 03:34:19 pm »
Also, if you wanted to go Pi/JAMMA there's now this little beauty on KLOV...
http://forums.arcade-museum.com/showthread.php?t=363338
That one I did like!!! And the games loads fast!
« Last Edit: March 04, 2016, 09:28:12 pm by johnrt »
johnrt
« Reply #275 on: December 14, 2015, 06:06:30 pm »
You know, I just placed a random monitor picture into the plans in photoshop. I think I'll trust Chance's measurements. But I obviously didn't miss completely.
« Last Edit: March 04, 2016, 09:28:37 pm by johnrt »
johnrt
« Reply #276 on: January 02, 2016, 04:34:03 pm »
So it's time to restore progress on this build also. And now I need these measurements for the service button bracket(A, B, C, D): Chance? Anyone?
« Last Edit: March 04, 2016, 09:28:19 pm by johnrt »
ChanceKJ
« Reply #277 on: January 02, 2016, 04:51:59 pm »
« Last Edit: March 19, 2021, 03:20:02 am by ChanceKJ »
johnrt
« Reply #278 on: January 02, 2016, 04:53:05 pm »
Thanks Chance!  :applaud:
« Last Edit: March 04, 2016, 09:28:27 pm by johnrt »
ChanceKJ
« Reply #279 on: January 02, 2016, 04:53:32 pm »
« Last Edit: March 19, 2021, 03:19:50 am by ChanceKJ »
