Author Topic: mala crash on screensaver  (Read 8863 times)
raph
  • Last login:May 25, 2024, 03:21:37 am
  • Gradually adding bells and whistles to a stock cab
« on: August 24, 2015, 03:47:45 am »
Mala is reliably crashing when the screensaver kicks in. It doesn't matter if it is the Mala built in one, or the Windows ones -- and it doesn't matter which Windows one it is.
The symptom is that it pops exception dialogs repeatedly multiple times a second, until manually killed:
2015/08/24  00:28:43.10   Debug **: WMPOWERBROADCAST: Received Screen Saver start message
2015/08/24  00:28:43.15   Error: Exception Message: System Error.  Code: 5.
Access is denied, Object Function: AppDeactivate, Exception Class: EOSError, Object Class: TTimer
2015/08/24  00:28:43.21   Error: Exception Message: System Error.  Code: 5.
2015/08/24  00:28:43.27   Error: Exception Message: System Error.  Code: 5.
2015/08/24  00:28:43.34   Error: Exception Message: System Error.  Code: 5.
2015/08/24  00:28:43.40   Error: Exception Message: System Error.  Code: 5.
2015/08/24  00:28:43.46   Error: Exception Message: System Error.  Code: 5.
2015/08/24  00:28:43.52   Error: Exception Message: System Error.  Code: 5.
2015/08/24  00:28:43.58   Error: Exception Message: System Error.  Code: 5.
2015/08/24  00:28:43.65   Error: Exception Message: System Error.  Code: 5.
2015/08/24  00:28:43.71   Error: Exception Message: System Error.  Code: 5.
2015/08/24  00:28:43.77   Error: Exception Message: System Error.  Code: 5.
2015/08/24  00:28:43.84   Error: Exception Message: System Error.  Code: 5.
2015/08/24  00:28:43.90   Error: Exception Message: System Error.  Code: 5.
Running no screensaver and using power options to turn off the monitors instead seems to work, but I would rather not do that as one of my monitors (the marquee one) displays "no sync" rather than going blank.
Alternatively, I could just not leave mala running. :(
I've tried both Mala174 and the beta, same effect.
raph
Re: mala crash on screensaver
« Reply #1 on: August 24, 2015, 11:52:18 am »
Additional info:
Running Windows 10.
Doesn't matter if it compatibility mode for Win 7, Win 8, or whether run as administrator.
raph
« Reply #2 on: August 24, 2015, 11:10:59 pm »
My interim workaround is to use AHK to turn off the screensaver when Mala launches, with this little utility: http://www.jddesign.co.uk/products/freeware/freeware_programs.htm#FlipSS
I then turn it back on on program exit.
Basically,
Code: [Select]
Run FlipSS.exe /off
RunWait D:\Frontends\MaLa\MaLa174\mala.exe
Run FlipSS.exe /on
ExitApp
I'd still love any insight anyone has.
raph
« Reply #3 on: April 24, 2017, 11:51:25 pm »
It's been years, but: it turns out that I was recently able to get the MaLa screensaver to work by pointing it at a directory with way fewer images in it.
loadman
  • Moderator
    • MaLa
« Reply #4 on: May 19, 2017, 02:31:44 am »
Thanks for the feedback
Ho many images set it over the limit?
raph
« Reply #5 on: May 19, 2017, 03:14:50 am »
It was the MAME snap directory; I have a couple of these for different versions, and the one with 29k images definitely did it. I think so did the one with 10k, though.
The one that works OK is my menu_snaps folder, used for snaps for the menus only, and it only has 159 in it.
 I haven't tried doing incremental tests, but I could if it would help. A binary search to find the tipping point would be tedious, but wouldn't take THAT long.
From watching it happen, I suspect it is something as simple as building the list of filenames to choose from, just taking too long.
