Author Topic: Supermodel UI on mala  (Read 4011 times)
ramos8414
  • Last login:January 09, 2019, 08:27:24 pm
« on: August 20, 2015, 01:40:59 am »
I am using Supermodel UI when I try to start a game from mala it loads the Supermodel UI but it doesnt start the game unless I click on the game then click PLAY?
burn_654
  • Last login:April 29, 2025, 04:25:44 pm
Re: Supermodel UI on mala
« Reply #1 on: August 21, 2015, 09:02:26 am »
Do you need to explicitly use the UI while in Mala? I would read through the manual for Supermodel itself and use just the command line version - it should be pretty easy to add the exe in mala and give that a path/argument for your rom file. If you need to change some additional options you could do that from within the UI.
ramos8414
« Reply #2 on: August 21, 2015, 04:34:52 pm »
I tried that but it doesnt use the control configuration I setup in the UI. I dont need to use the UI, I just want to launch the games from Mala.
Wade007
  • Last login:April 06, 2017, 01:33:35 pm
  • A MAME cabinet at home is heaven
    • bit.ly/1cWnoIC
    • Cheapskategamer.com
« Reply #3 on: August 23, 2015, 03:22:06 pm »
Yes, you can launch Supermodel with Mala. I did it. Runs great. See thread below, especially the very last (mine) entry. Gives two options to launch Supermodel 3 games with Mala:
http://forum.arcadecontrols.com/index.php/topic,121054.msg1284095.html#msg1284095
« Last Edit: August 23, 2015, 03:25:09 pm by Wade007 »
My Super Arcade cabinet project:
Software blog article: http://bit.ly/1cWnoIC
Hardware blog article: http://bit.ly/1dWxjvP
YouTube video: http://bit.ly/1N818Xm
Super Arcade Cabinet Progress thread (Now Complete):
http://forum.arcadecontrols.com/index.php/topic,123292.0.html
Frontend Video Intro: http://bit.ly/1P9HPDN
ramos8414
« Reply #4 on: August 23, 2015, 06:57:01 pm »
It worked but when I changed the resolution the controls stopped working I setup the inputs in with the supermodel.exe bit it still didnt work. Ill just play the Dreamcast version of  VF3. Thanks anyway.
