Author Topic: How do I connect a Medium Res. monitor to a PC??  (Read 2501 times)
BLACK KNIGHT
  • Last login:March 09, 2019, 08:02:19 pm
  • I'm a llama! A what?!
    • Mike's X-Arcade
« on: January 05, 2004, 03:26:08 pm »
Okay, I have a Virtua Fighter cabinet with a 25" monitor in it.  According to KLOV it is a medium resolution monitor.  I'd like to convert this to a MAME machine...but I don't know what is involved in connecting a PC to it.  Do I need the arcadevga card from Ultimarc?  It looks like that is only for 15khz monitors.  Is there a way to wire it directly to a normal video card or something??
Dak-ak
  • Last login:July 29, 2008, 05:14:50 pm
  • RSD: Redefining Slacking Daily
Re:How do I connect a Medium Res. monitor to a PC??
« Reply #1 on: January 05, 2004, 03:38:31 pm »
a normal video card under windows will display a 31Khz signal, and you need a ~25Khz signal.
I think a program like advancemame can produce that.  Do you know what resolution that virtua fighter runs at?
BLACK KNIGHT
    • Mike's X-Arcade
« Reply #2 on: January 05, 2004, 04:02:21 pm »
No, but I believe I read that medium res monitors run at 640x512 or something like that?
Brad
  • Last login:August 03, 2018, 05:43:23 pm
    • www.emuchrist.org
« Reply #3 on: January 05, 2004, 04:42:59 pm »
Advance Mame with a hacked VGA cable will definitely run on that Monitor.
Brad
Dak-ak
« Reply #4 on: January 05, 2004, 04:52:26 pm »
I'm personally experimenting with Linux on different monitors (my standard res) and am pretty happy... its standard windows system can produce the modes required...
http://advancemame.sourceforge.net/ (check out advanceCD... cool idea!)
http://www.mail-archive.com/xfree86@xfree86.org/msg10902.html (xfree and advance mame modelines are near identical)
http://www.msu.edu/user/jonesdes/html/advcfg.htm
http://easymamecab.mameworld.net/html/monitor1.htm (by page 9 you should be /smart/  ;))
BLACK KNIGHT
    • Mike's X-Arcade
« Reply #5 on: January 05, 2004, 04:52:51 pm »
Okay, anyone know how I'd have to hack a video cable to get it to work?
Dak-ak
« Reply #6 on: January 05, 2004, 05:45:52 pm »
i would hazard the same way you would hook up a standard rez :-)
I wired directly to my monitors board ALA ultimarc because i was stripping and dumping its old JAMMA wiring... you may or may not be keeping it.
http://www.mameworld.net/pc2jamma/pc_arc3.html
http://www.ultimarc.com/monfaq.html#monitorcable
StephenH
« Reply #7 on: January 05, 2004, 10:53:17 pm »
One way is to use AdvanceMAME with a card that can output a 25Khz signal.
Another way is to use a scan converter.
Still another is to use an old EGA graphics card
Brad
    • www.emuchrist.org
« Reply #8 on: January 05, 2004, 11:15:06 pm »
I used this guide to great effect! Print out the molex connector guide too.
http://dragonsden.emuunlim.com/ddvgatutl.htm
Brad
Dak-ak
« Reply #9 on: January 06, 2004, 05:51:20 pm »
