Author Topic: from sketchup to illustrator  (Read 1864 times)
kiel0909
  • Last login:May 23, 2022, 02:59:10 pm
« on: August 13, 2015, 03:08:06 pm »
So Ive got my cab in sketchup.  i want to get the profile to illustrator so that i can print it out at staples on paper and trace the outline to the MDF.  but i cant seem to find a clean way of doing so.   i dont want to print screen and live trace.  i feel like there has to be a better way.
how are you getting your exact cab profiles into illustrator for art?
JDFan
Re: from sketchup to illustrator
« Reply #1 on: August 13, 2015, 03:14:22 pm »
Been a while but IIRC sketchup can export 2d models to .PDF format which can then be imported to illustrator.
kiel0909
« Reply #2 on: August 13, 2015, 06:39:07 pm »
i only see jpg bmp tiff and png sadly
JDFan
« Reply #3 on: August 13, 2015, 06:50:47 pm »
Illustrator can open jpg, tiff, and png. ( then just have to make sure the measurements are correct for printing with the rulers and guide lines )
kiel0909
« Reply #4 on: August 13, 2015, 06:52:25 pm »
this is true, i was just hoping for a less "eyeball-y" way of making it happen
JDFan
« Reply #5 on: August 13, 2015, 06:54:03 pm »
Seems PDF is only supported in the Pro version of sketchup - but using the ruler you should be able to get it sized correctly fairly easily after import.
2D Graphic (PDF/EPS) Export
This is a Pro only feature.
SketchUp allows you to export your models as 2D vector drawings, including PDF and EPS. Export a file using the Export > 2D Graphic menu item in the File menu.
