Author Topic: Happ Competition diagonals mod?  (Read 3268 times)
Mr. Peabody
  • Last login:February 12, 2026, 12:32:17 am
« on: August 12, 2015, 05:25:12 pm »
Hi. Occasional lurker. I picked up a mame cab with Happ Competition joysticks which I like except for the diagonals. Is there a mod to make them easier to reach? Thanks.
mgb
  • North East, US
Re: Happ Competition diagonals mod?
« Reply #1 on: August 12, 2015, 07:18:26 pm »
I wouldn't really think so because of the way that stick is with the big square actuator.
It seems like there would be much you do with it.
I used to use comps and I thought they were pretty decent on diagonals, I thought that was the whole idea of the square actuator. But I do see a lot of people complaint of bad diagonals
You may prefer switching to a Super, the blades on the switches make it a little more tweak-able.
JDFan
« Reply #2 on: August 12, 2015, 07:34:16 pm »
You could try wrapping the actuator with some electrical tape or similar to make it a bit larger (not sure how it would hold up )
« Reply #3 on: August 12, 2015, 08:08:04 pm »
This method works and lasts a while but is not a permanent solution.  Maybe I should 3D print some bigger actuators for comps and retire on the hundreds of pennies I'd make.
Mr. Peabody
« Reply #4 on: August 15, 2015, 03:39:22 pm »
I don't have electrical tape, but I tried some duct tape, and it got messed up quickly. Found that the left actuator was broken or made wrong because it wouldn't fasten onto the housing cylinder like the right does; I swapped them and they each worked, and didn't, the same way; a strip of paper sandwiched inside the two fixed the bad one in place, for now at least. Anyways, I may have to replace them. The 4-way stick is a Super and it's one of the best microswitch 4-way sticks I've experienced. Maybe I'll replace the Competitions with Supers.
jamesjones626
  • Last login:March 08, 2025, 01:58:57 am
« Reply #5 on: August 15, 2015, 08:20:40 pm »
I have a competition stick and I have to say that its a real pain to hit the diagonals.  Bought because I read it was suppose to be easy.
Sent from my Z993 using Tapatalk
mgb
  • North East, US
« Reply #6 on: August 16, 2015, 10:08:19 am »
By left and right actuators, are you talking about the microswitches.
Any pics?
RandyT
  • Last login:Yesterday at 11:28:34 am
    • GroovyGameGear.com
« Reply #7 on: August 17, 2015, 01:58:43 am »
Harder to hit diagonals, is a feature of the Competition sticks.  It makes them a bit more suited for both 4 and 8-way titles.  Making the diagonals easier to hit, will make 4-way games less playable.  If decent 4-way performance is important, and the panel already has a dedicated 4-way, then increasing the diagonal sensitivity is probably desirable.
With the Competitions, there's really only one way to achieve this.  Different microswitches will have different length actuation "nubs", and will also actuate at different points in their travel.  So the answer is to do some experimenting with different switches, to find which will provide the desired actuation zone sizes.
Mr. Peabody
« Reply #8 on: August 21, 2015, 04:17:55 pm »
I meant the left stick's actuator was broken.
@Randy: I haven't thought about Competitions being designed for 8-way and 4-way. I thought of putting Super switches in....but it's probably easiest to just buy some Supers.
Purple Tophat
  • Last login:May 27, 2025, 09:56:12 pm
  • Will pay cash for working time machine
« Reply #9 on: August 25, 2015, 04:58:31 pm »
Copying this over from an older post asking the same question. Not sure if the pricing is still the same, but in your case you would just want the gold switches and springs anyways since you already have the sticks:
Not sure if this reply comes way too late, but Happ actually sells a "Williams Modified" Competition Joystick. You can find it on their site, but some vendors can actually get them for you cheaper than you can get them yourself. They come with gold microswitches with a higher actuation point, as well as harder springs. Basically they were the ones Williams used for their Mortal Kombat Games. The diagonals are way easier to hit, as that is critical for those games. I have them for my MAME project that I am finally getting back into working on, and my friend has had them on his MK/MAME cab for years. They are perfect!
The modified ones are $21.75 instead of the $14.99 for normal Competition sticks from HAPP directly, but as I said, some industry vendors can get them for your cheaper. Arcadeemulator.net was able to order them for me cheaper. Check it out here: http://na.suzohapp.com/all_catalogs/joysticks/50-6071-16
Part # 50-6071-16
You can also just buy the gold switches and the hard spring, swap them out yourself, and biggitty bam, you got yourself a true MK arcade fighter stick with good diagonals.
Unbeatable Mortal Kombat Master
Mr. Peabody
« Reply #10 on: September 04, 2015, 04:56:40 pm »
Thanks, Purple Tophat. I'm curious to see, but I don't know as I'm that curious given my recent experience with leaf switch sticks.
