Author Topic: Monitor Discoloration  (Read 1595 times)
alomar123
  • Last login:June 15, 2017, 01:36:25 pm
« on: August 06, 2015, 11:50:29 pm »
Before I buy this Donkey Kong cab, could someone inform me what may be wrong with the monitor and is it an easy fix?  Thanks
fings1
  • Last login:September 04, 2023, 02:16:00 pm
Re: Monitor Discoloration
« Reply #1 on: August 07, 2015, 08:55:23 am »
Looks like it is just a degaussing issue.  When machines get moved around, the magnetism around monitors can make the screen show funky colors. The monitor has a degaussing coil that Should fix it. You turn off the machine for 20 minutes or so and then turn back on. Should resolve the issue...sometimes I've had to do it a few times.
Hope that helps.
alomar123
« Reply #2 on: August 07, 2015, 08:57:10 am »
Thank you for your response. I just wanted to make sure I wasn't getting over my head with this buy.
« Reply #3 on: August 07, 2015, 09:54:30 am »
it looks like either degauss or magnetic feedback, cant say if theres anything more than that wrong with it without it being in front of me.  IF its only degauss its a pretty easy fix.
alomar123
« Reply #4 on: August 11, 2015, 01:28:19 pm »
Degaussing worked a miracle. Thanks
« Reply #5 on: August 11, 2015, 01:35:11 pm »
wow, looks perfect!  :applaud:
