Author Topic: Janky Kong - The Final Frontier  (Read 91769 times)
Re: Janky Kong - Now in Phase Two
« Reply #240 on: September 22, 2015, 04:29:01 pm »
I may snag it then.  Anyone know if the PPU that is there that work with Tetris will also work for SMB?  I'm thinking a can clear the EPROMS and burn new ones.  Yotsuya I'm talking to you...
Edit:  I just looked it up and SMB requires the PP2C04-0004 PPU.  Tetris comes with either the PC2C03B PPU or the RP2C04-0001 PPU.
D
« Last Edit: September 22, 2015, 04:40:41 pm by DeLuSioNal29 »
« Reply #241 on: September 22, 2015, 05:07:05 pm »
Well, if you buy two UniVersuses, it won't matter. But if you want to convert them to another game, I'm happy to help.
« Reply #242 on: September 22, 2015, 05:08:38 pm »
I would snag it because it comes with the harness. If you're planning to run all original hardware, you'll definitely need that. I'm going to go to JAMMA on mine, so I haven't been looking for a harness. I did bid on one early on, but I went for way more than I would pay for it.
ChanceKJ
« Reply #243 on: September 22, 2015, 07:21:16 pm »
http://johnsarcade.com/nintendo_vs_ppu_info.php
For those of you who don't know.  Just in case.
« Reply #244 on: September 25, 2015, 12:54:35 pm »
Janky update:
Ok, I've got some time now and will go back to fill in on the process.
My all-in-one board works great. Having the J-Pac, HD, and Mini-ITX board all on one plate sure is handy. Clearances are a little tight, so if I ever fab a new one, I will make it a bit bigger and add just a little more space between the motherboard and the J-Pac*. But I screwed in on to the side of the cab, mounted the power supply on the floor of the cab, and fired it up.
I had to tweak the system a bit, as it was booting up to a blue screen when hooked to the ArcadeVGA. I figured out why, though - the board, while unused, had sat for a long time, and the cheap battery that holds the CMOS settings wasn't keeping them, so the board booted to the on-board video and not the ArcadeVGA. I replaced that battery with a new one for better results.
So once I got the boot issues sorted out, I went ahead a played with the OS setup and the front end. I used Instant Sheller to mask off the FE, made a custom boot screen for the PC, and have it autologin.
It comes up to my list of Vs Unisystem Games.
More later!
*Actually, I did JUST THAT right now as I typed this post.... gonna fab it in an hour. :)**
** OK, fabbed it before I even finished this post. W00t!
« Last Edit: September 25, 2015, 12:56:07 pm by yotsuya »
« Reply #245 on: September 25, 2015, 01:08:18 pm »
Once I had it all up and running, I immediately noticed that I couldn't go down or left. I cracked out my new Fluke, set it to continuity, and saw that I needed to re-crimp down, left and Coin 2 on the JAMMA harness. That was an easy fix.
I've been playing a lot on this cab. I loved Excitebike BITD as well as Castlevania. I'm mulling whether to add a few NES games to it, like a Playchoice. I'm also waiting on some new marquee and bezel art as well, some simple custom Unisystem stuff.
« Reply #246 on: September 25, 2015, 01:44:05 pm »
I would totally load up some NES games. No point in limiting yourself.  I would love to play some Bases Loaded on that bad boy.
« Reply #247 on: September 25, 2015, 01:59:22 pm »
game creep...
 :afro:
I love it dude, did you machine that plate in your garage or do you got a guy?
« Reply #248 on: September 25, 2015, 01:59:41 pm »
Loved Bases Loaded.
Off the top of my head, I'd want to add the other SMB games, Castlevania games, Double Dribble and Blades of Steel, games that could be played in short sessions. I love Final Fantasy but I ain't marathoning that on a cab.
« Reply #249 on: September 25, 2015, 02:01:14 pm »
game creep...
 :afro:
Yeah, don't worry, I ain't puttin' Mario Paint or any Zapper games on it.
And ---fudgesicle--- me, 10 Yard Fight is near impossible....
Oh, I have access to a Plasma cutter at work. I tweaked my design and recut it.
« Reply #250 on: September 25, 2015, 05:50:15 pm »
I really can't think of this as Janky Kong any more. Everything about it is becoming the opposite of janky.
« Reply #251 on: September 25, 2015, 05:51:09 pm »
Thanks. I consider Janky Kong a term of endearment!
« Reply #252 on: September 25, 2015, 06:09:11 pm »
I'm waiting on my new bezel to get printed, but here's a sample.
ChanceKJ
« Reply #253 on: September 25, 2015, 07:40:24 pm »
who's doing your print work for your art package?
« Reply #254 on: September 25, 2015, 09:05:44 pm »
I got a local connection. Going to trade something for my laminated marquee and bezel.
Otherwise, I'd go with Brad or Stpcore.
« Reply #255 on: September 25, 2015, 09:10:19 pm »
Comparison time! Old plate....
« Reply #256 on: September 25, 2015, 09:12:38 pm »
New plate! I added an inch in length, moved the motherboard away from the J-Pac to open up the cabling area, added a hole for the HD access light, and two holes for a 36" zip tie to secure the video card. A winner is me!
DGP
  • Gamer4Life
    • My Toys...
« Reply #257 on: September 25, 2015, 11:25:29 pm »
No cup holder on that plate = Janky.
« Reply #258 on: September 25, 2015, 11:49:53 pm »
Fake rep for you!
« Reply #259 on: September 26, 2015, 12:02:43 am »
If anyone wants the  old plate, lemme know.
« Reply #260 on: September 26, 2015, 12:35:33 am »
Classy! What kind of fasteners you have on that mobo?
« Reply #261 on: September 26, 2015, 12:49:42 am »
That plate is cool. You have inspired me to up my game when I get to my JPAC build. Using a cased PC just seems so wrong now.
« Reply #262 on: September 26, 2015, 12:52:18 am »
I use some screw caps that I got from Home Depot. They flip up if I need to access the screw heads.
It's pretty awesome. The holes in the plate are spot on, so I leave the screws in capped, and they easily slide into the holes. I hand-tighten the nuts on the back, so I never even need to use a screwdriver to fasten the mobo to the plate. The SSD screws go into the bottom of the drive through the back with spacers. I also use spacers and three screws with the J-PAC as well, and I leave enough overhang for the JAMMA connector.
Yeah, I prefer decased machines in my own builds. I would mount them to 1/2 wood boards, but the plate just has much more flair.
« Last Edit: September 26, 2015, 12:53:57 am by yotsuya »
« Reply #263 on: September 26, 2015, 12:53:25 am »
Is it OK to make it from Metal?  I usually make mine from non-conductive material like wood. Wood also allows me to screw the video card into it by bending the bottom of the metal slider and using a Bic pen cylinder cut to size for the gap.
Edit:  I guess it's OK. Most PC cases have a metal plate with standoffs anyway.
DeL
« Reply #264 on: September 26, 2015, 12:55:36 am »
DeL
I use nylon spacers between the plate and all components.
« Reply #265 on: September 26, 2015, 12:57:10 am »
Thanks for the tip, I will have to keep that one in mind next board mount I do.
« Reply #266 on: September 26, 2015, 12:59:43 am »
It just looks cleaner that way. :cheers:
This photo of the old plate should show how much clearance there is.
ChanceKJ
« Reply #267 on: September 26, 2015, 01:13:55 am »
Did you ever convince stpcore to do a reverse print? I saw in that one thread you had been asking him about it.  Did you find a source for doing it?
« Reply #268 on: September 26, 2015, 01:15:53 am »
No. No reverse print. Just laminated. Very durable - my buddy just dropped it off.
« Reply #269 on: September 26, 2015, 09:49:03 am »
Chance if you need reverse print I know a guy:  Joe Szabo. And he does things quickly. :-)
« Reply #270 on: September 26, 2015, 10:30:54 pm »
Super bad photo, I know, but if you look closely, you can clearly see Hogan's  Alley running on this Duck Hunt cab. Yes, I took my Janky Unisystem board that I Frankensteined together to StarFighters Arcade,  we plugged it in to Duck Hunt, and yes, the ---Bad words, bad words, whatcha gonna do? Whatcha gonna do when saint censors you?--- booted! W00t!!!
« Reply #271 on: September 27, 2015, 01:43:55 am »
Woot!
« Reply #272 on: September 27, 2015, 01:59:40 am »
Woot!
Yep. There were hugs all around when I saw that mofo boot up!
vwalbridge
« Reply #273 on: September 28, 2015, 11:35:51 am »
I really like that mounting plate. It's awesome that you have access to a fabrication facility.  ;)
What finish is on that plate? It looks like gunmetal and I like it.
« Reply #274 on: September 28, 2015, 11:46:18 am »
It's just a piece of 16GA sheet metal that I hit with a random orbital sander to give it some texture and take off any finish. Looks great once it's cleaned up. I toyed with painting it something flaky metallic (like a midnight blue), but in the end, the metal is the best.
« Reply #275 on: September 28, 2015, 11:47:34 am »
Oh, and what's nice about the plate is that if I DO go the original Unisystem PCB route, I can easily take the plate out and transfer it to another project.  :cheers:
vwalbridge
« Reply #276 on: September 28, 2015, 11:48:32 am »
I like the way you think brother!
« Reply #277 on: September 28, 2015, 12:23:51 pm »
Yeah, I've been doing these plates for a while now. My original design was just for the motherboard, and I had a large cutout under it for the a custom graphic that would basically be a mini-marquee (see attached). I used this on a cab I build for my friend. The next version got rid of the cutout and integrated the hard drive and J-Pac. The latest version spaces things out better, as I didn't take into account the cabling between the J-Pac and the motherboard. Hella chuffed with were it's at now.
« Reply #278 on: October 03, 2015, 07:46:35 pm »
Small update, cut  a piece of plexi and mounted the custom marquee I designed.
« Reply #279 on: October 03, 2015, 07:47:49 pm »
Urp... attached photo
