Author Topic: Keeping TV on after power loss  (Read 2454 times)
gprime
  • Last login:November 02, 2024, 01:23:19 pm
  • still the newb
    • G-Prime .NET
« on: January 04, 2004, 02:39:58 am »
I could have sworn this was discussed somewhere alreadty but searching resulted in nothing. Anywho; I got a nice TV for cabinet, but after I turn the power off and then back on, it's off by default. I tried jamming the power switch down also. Still didn't work. I either have to a) always keep it on (big waste of power? -- and no there is no standby mode :() or b) use the remote to turn it on everytime i want to play (really takes alot from the authenticity of it -- and it's hard not losing a remote).
Are there any kind of hacks to keep it on after power loss? If I was a genious maybe I could build a small infared device to send the "on" signal everytime I hit the power switch -- but that's pretty far fetched.
Anyone else in this situation?
icsdiode
  • Newbie
  • Last login:January 04, 2004, 12:01:54 pm
Re:Keeping TV on after power loss
« Reply #1 on: January 04, 2004, 12:02:59 pm »
What brand of tv are you using?
eightbit
  • My cab is never done...
« Reply #2 on: January 04, 2004, 04:42:36 pm »
If the jam the button doesn't work  then its going to be a little harder. There is no universal trick to make the tv work. Different tv's have different electronics.
You can look into either making your own IR device like you mentioned or you can look into ready made IR solutions like from X10.
Zombie
  • Last login:September 09, 2016, 07:14:59 pm
    • zombie's homepage
« Reply #3 on: January 05, 2004, 12:33:18 pm »
not sure but you could hack the remote and mount a button on the cabinet, that way the remote wouldnt get lost.
i was planning to do something like that but luckly found a TV which auto powered up.
Stingray
« Reply #4 on: January 05, 2004, 02:44:31 pm »
That's exactly what I had in mind for mine. Is there any reason why this wouldn't work? Seems a good idea to me.
-S
TalkingOctopus
    • My Arcade
« Reply #5 on: January 05, 2004, 02:47:04 pm »
Buy a cheap Universal remote and hook the power button up to an arcade push button.  That is what I did to solve this problem.
gprime
  • still the newb
    • G-Prime .NET
« Reply #6 on: January 07, 2004, 12:30:21 pm »
Sorry I always forget about my threads :)
The television is a 20" Prima Q2016. The remote hack seems very interesting. Actually, for some reason this television even came with a univeral remote. Thanks for all the replies!
GamingGreg
  • Last login:August 05, 2018, 06:04:30 pm
« Reply #7 on: January 07, 2004, 02:48:57 pm »
If you don't mind hacking into the TV, you could also hard wire the power button to an arcade button as well.  Obviously this will void any warranty on the TV, but if that's not an issue, then hack away.  This is similar to the remote solution, but it removes IR from the equation.
gprime
  • still the newb
    • G-Prime .NET
« Reply #8 on: January 07, 2004, 06:18:32 pm »
I managed to hook it up without ruining my remote  ;D
kdiddy13
  • Last login:January 05, 2009, 02:04:07 pm
  • Love da llama!
    • Galaxy 12 Entertainment
« Reply #9 on: February 11, 2004, 06:35:03 pm »
Um.... How?
