Author Topic: Silver Strike converted to Golden Tee?  (Read 2993 times)
Brian12
  • Last login:November 12, 2016, 07:23:57 pm
  • Today is a new day...
« on: July 30, 2015, 03:36:25 pm »
I just picked up at auction a Silver Strike Bowling 2005/06? for a good price (unknown if it worked) and I plugged it in and works fine...I only did this because of the price and I lost out on a Golden Tee 2008 Live...I was hoping since the NightHawk 2.0 (CPU) is the same of golden tee I could start from there...i know I would need to upgrade the DIMM and Video Card...Could I use that and piece together a Golden Tee game? What would I need to change out?
-Brian
« Last Edit: July 30, 2015, 04:41:29 pm by Brian12 »
lilshawn
  • Last login:Yesterday at 07:52:16 pm
Re: Silver Strike converted to Golden Tee?
« Reply #1 on: July 31, 2015, 10:27:24 am »
there is a security chip, the cabinet ID module is locked to only be used with SSB and the computer hardware (the make and model of which is coded to the game) is different. by the time you purchase a replacement CID, the security chip, and the upgraded hardware needed for GT (which is not available new anymore so you'd have to buy used), you might as well buy a brand new kit.
actually to correct myself, new hardware IS available, but you have to buy the newest 2015 version to be able to use new hardware.
the CID is a small  square circuit board (1" 1/2 x 2") with a USB cable attached, put someplace inside the cabinet...it's ID number starts with something like 15-xxxxx or 17-xxxxx etc. the first 2 digits denote if its silver strike bowling, bags, or golden tee and so on. each has it's own number. I've looked into possibly reprogramming the CID's but it's way over my head.
Brian12
« Reply #2 on: July 31, 2015, 11:38:12 pm »
So basically I need to find a Nighthawk from a Golden Tee Live game 2005 or newer with a CID?  :banghead:
lilshawn
« Reply #3 on: August 01, 2015, 07:06:21 pm »
basically.
