Author Topic: ROM Lists FrontEnd MESS  (Read 1523 times)
AMDman13
  • Last login:April 08, 2023, 09:21:58 pm
  • This Cab is going to be the end of me!!
« on: July 22, 2015, 02:38:52 pm »
Is there anyway for a Frontend such as Mala or Mamewah to read MESS's individual system dats or xml in order for the FE to deliver a gamelist that is not simply the name of the rom.zip?
My old user name was marlborroman13, but I kicked the habit many years ago!
phulshof
  • Last login:December 01, 2025, 06:24:56 pm
    • Pieter's Webpage
Re: ROM Lists FrontEnd MESS
« Reply #1 on: July 22, 2015, 05:06:21 pm »
RetroFE can do it.
AMDman13
« Reply #2 on: July 22, 2015, 05:35:54 pm »
Looks pretty sweet. I'll give it a go
NOP
  • Last login:September 19, 2017, 08:22:27 pm
  • I stole my avatar.
    • winterMAME
« Reply #3 on: July 22, 2015, 08:59:08 pm »
romlister should also be able to import mess xml files, allowing you to export them to any FE.
it is a new and lightly tested feature though, so give me feedback if it's not what you're looking for.
AMDman13
« Reply #4 on: July 23, 2015, 10:54:04 pm »
Oh yea. Rom Lister! I forgot about this nice little utility. I am not sure it can do what I want though? I am looking for a read friendly list. Usually your FE will read Mame.xml to create a friendly title for each game instead of simply the rom name. Maybe if it can create a custom dat_file then we would be in business. At any rate. Thanks for reminding me of this utility. Now I can remove and clean up some of my roms.
AMDman13
« Reply #5 on: July 24, 2015, 12:07:37 am »
FYI ROMlister worked like a charm! Simply point romlister to the hash directory and select the individual system xml file. Then create the list. I use MameWah and low and behold romlister can use the info in the xml file to create a nice clean list! Many thanks!
