Author Topic: Led monitor problem  (Read 2135 times)
800screws
  • Last login:November 10, 2019, 07:37:29 am
Led monitor problem
« on: July 21, 2015, 05:09:58 pm »
I just swapped my neo cabinet to a led lg computer monitor.  It has wavy lines that scroll on the monitor.  It's not the picture but if it's a solid background color u can really notice it.  My atomiswave does it also running straight out with the vga cable.   Is this how led's look? It doesn't do it with a lcd I have.   If need be I'll get pics later.
lamprey
Re: Led monitor problem
« Reply #1 on: July 21, 2015, 05:46:34 pm »
I'm not sure from your description, but is it possible that the monitor refresh rate is not the same as the game causing screen tearing?
800screws
« Reply #2 on: July 22, 2015, 10:50:19 am »
Here's a pic.   Anyway to fix it? Here's the lg mode number. 32WL30MS-B
« Reply #3 on: July 22, 2015, 12:26:15 pm »
How are you hooking it up is really the question?  Do you have any pics of the connectors, boards, etc?
800screws
« Reply #4 on: July 22, 2015, 12:43:52 pm »
that pic is coming straight out of the atomiswave with the vga output straight into the monitor....
its the same when I have it coming from the neo geo board through a cga to vga converter........
« Last Edit: July 22, 2015, 02:34:42 pm by 800screws »
« Reply #5 on: July 22, 2015, 04:12:12 pm »
I'm guessing it's a refresh rate issue that the new LED monitor is not supporting.  You say the LCD works correct?
D
800screws
« Reply #6 on: July 22, 2015, 04:28:45 pm »
Yup I just swapped the atomiswave into my muticade with a lcd and it works fine and clear.    What can u do to fix it?
I did order one of those shyntek's
« Last Edit: July 22, 2015, 05:20:48 pm by 800screws »
grantspain
« Reply #7 on: July 22, 2015, 06:54:33 pm »
thats either a rubbish quality vga cable(most are) or an earth issue
800screws
« Reply #8 on: July 22, 2015, 07:46:43 pm »
I'll try another cable tomorrow
800screws
« Reply #9 on: July 24, 2015, 10:53:19 am »
Holy crap.   That's all it was.   Thanks guys
