Author Topic: rowe cadette cmm4  (Read 5092 times)
andy schwarz
  • Last login:November 20, 2022, 09:41:50 am
rowe cadette cmm4
« on: July 20, 2015, 05:18:16 pm »
Hi all jukers
My name is Andy i am a novise juker and have now got my self a Rowe cadette CMM4 for restoration.
it is in a OK condition so it will be a challenge so i am hoping that you guys out there can share your skills with me.
the wiring is a bit up in the air and i cant seem to find a wire diagram for it.
i am sure the amp i have does not match the pre amp.
pre amp is  r 4570a
amp is r 2255a.
il try and post some pics later
many thanks
andy
andy schwarz
Re: rowe cadette cmm4
« Reply #1 on: July 20, 2015, 05:43:55 pm »
this is the inside of the rowe cmm4 cadette
ami-man
  • Last login:July 19, 2020, 01:22:45 pm
« Reply #2 on: July 21, 2015, 04:49:33 am »
Hi Andy,
Welcome to the forum.
You have got your work cut out there, that mechanism needs fully striping down and rebuilding.
If you let us know what country you live in we can point you in the right direction to purchase a manual. You will need one in order to undertake all the mechanism adjustments when you start rebuilding it.
You will need to check all the parts for wear and replace them when needed, I can see that some of the wire dividers on the basket/carousel are bent,  take care to get these right.
Regards
Alan
Alan Hood
ami-man
UK
andy schwarz
« Reply #3 on: July 22, 2015, 03:04:14 pm »
Hi Alan
Thank you for the advice, I have a manual ect on its way.
What I am confused about is the amp and pre amp installed in this juke.
The amp is R2255 the pre amp is 4570 the pe amp board inside is a 2253, im thinking that the amp R2255 does not need a pre amp as thire is no connect block to attach one.....is this correct.
I live south london so any contacts would be helpful.
I have restored a few Rock Olas but this is my first Rowe.
thanks for you help
andy
il try to post a few photos
ami-man
« Reply #4 on: July 23, 2015, 06:36:18 am »
Hi Andy.
There were several option on the amplifiwers used CMM range of Cadette's.
The Mono amp was the R-2255
The Hybrid Mono was R-4567
Stereo 50 watt R-4572 comprised of:-
Power amp 4359A
Pre-amp 4571 (this number just identifies the metal case the pre-amp number inside is the number that counts)
There was even an option of a 100 watt amplifier 601-02576
If you need any parts please contact me directly on 0114 247 0242 alan-hood@datex.co.uk.
Down your way is Leon Reader check out www.jukeboxparts.co.uk
Regards
Alan
Alan Hood
ami-man
UK
jamiva
  • Last login:December 14, 2019, 12:40:57 am
« Reply #5 on: December 10, 2019, 12:59:24 pm »
Hellou, can anyone help me? I have Ami Rowe CD 2 (CCM4) juke. Amplifier is mono R-2255 and it doesn't work,  i found out that problem is that smaller electoniccard. I despartly need schematic and part list... :)
Ken Layton
  • Guru
  • Technician
« Reply #6 on: December 10, 2019, 10:16:25 pm »
Where are you located?
jamiva
« Reply #7 on: December 10, 2019, 11:57:21 pm »
Finland, and i'can honestly say, it is very difficult to find parts...
Janne
