Author Topic: install error help  (Read 6266 times)
Slippyblade
install error help
« on: July 15, 2015, 01:18:36 am »
I'm trying to install Attract-Mode on a Linux system.  I DL'd the .deb package and tried to install it.  I'm not versed in Linux well enough to know what it means.  The error is:
Dependency not satisfiable.  libavresample (>= 6:9.16 - 0ubuntu0.14.04.1)
Googling this doesn't yield squat.  Any help would be appreciated.
General_Faliure
  • Last login:March 01, 2022, 07:30:40 am
    • My Arcade Cab
Re: install error help
« Reply #1 on: July 16, 2015, 07:36:12 am »
Are you using Ubuntu?
It installed fine for me on Linux Mint 17, which is based on Ubuntu 14.04
My Arcade cab: https://goo.gl/photos/yE1KACHryQjCaaCj7
Core2 duo8400 @3.6 Ghz, 4Gb of mem, Geforce 9500.
Linux Mint 17.3 XFCE, Mame, Mess, Daphne FS-Uae, Mednafen and some more.
Mah!cade
Slippyblade
« Reply #2 on: July 16, 2015, 02:23:26 pm »
Using Debian
What install method did you use?  Did you compile it or use the .deb files from the website?
General_Faliure
    • My Arcade Cab
« Reply #3 on: July 21, 2015, 02:45:03 am »
I used the .deb file. (64 bit)
Your Libav audio resampling library is not present or too old, installing the .deb should resolve this, but it may be different on Debian.
You could try installing it manualy.
Look for libavresample in your package manager, it should be newer then 6:9.16, on my system (linux mint) it is at: 6:9.18
Mah!cade
Slippyblade
« Reply #4 on: July 21, 2015, 03:51:33 am »
I'll try that, thanks for the suggestion.
raygun
  • Last login:January 07, 2016, 12:24:03 am
« Reply #5 on: July 21, 2015, 09:17:11 pm »
Hey Slippyblade, if you are still having problems with the .deb all the commands for compiling yourself on debian (stable) are posted here:  https://github.com/mickelson/attract/wiki/Compiling-on-Debian-Jessie-%28stable%29
Slippyblade
« Reply #6 on: July 21, 2015, 09:18:13 pm »
Yeah - tried that.  No go.  The compile failed with code errors.
General_Faliure
    • My Arcade Cab
« Reply #7 on: July 23, 2015, 09:21:47 am »
Which Debian are you using, maybe it's just too old.
Mah!cade
Slippyblade
« Reply #8 on: July 23, 2015, 03:09:52 pm »
Latest stable from the website.
General_Faliure
    • My Arcade Cab
« Reply #9 on: July 26, 2015, 07:15:11 am »
I am afraid i can't help you here.
I always use Ubuntu based systems (Lubuntu for my cab and Mint for my test system) and they suit me fine.
Mah!cade
