Author Topic: Transcoder  (Read 2726 times)
steved61
  • Last login:October 19, 2025, 01:05:53 pm
Transcoder
« on: July 11, 2015, 03:53:33 pm »
What transcoder is recommended now that the TC1600 is not available ?
steved61
Re: Transcoder
« Reply #1 on: July 19, 2015, 08:35:02 pm »
So nobody is using a Transcoder ? I want to go for VGA to Component.
Thanks for any help.
SteveD61
cyb
  • Last login:November 28, 2025, 06:54:51 pm
Re: Transcoder
« Reply #2 on: July 21, 2015, 02:28:33 am »
Kramer FC-14 is probably the best, but it's pretty rare these days. I've also heard good things about the Audio Authority 9a60.
steved61
Re: Transcoder
« Reply #3 on: July 21, 2015, 02:39:19 pm »
Thank you.
SteveD61
Paradroid
  • Last login:December 05, 2025, 10:28:19 pm
    • SCART Hunter
Re: Transcoder
« Reply #4 on: July 21, 2015, 06:08:52 pm »
All the transcoder info you hope for is in a thread just a little further down the page...
My MAME/SCART/CRT blog: SCART Hunter
steved61
Amra
  • Last login:July 27, 2024, 02:33:46 pm
  • Save a tree, Eat a beaver!
Re: Transcoder
« Reply #6 on: August 02, 2015, 06:54:54 pm »
Several people use that method, and even that exact encoder (myself included).  You can find a lot of information about that particular set-up in the following thread: http://forum.arcadecontrols.com/index.php/topic,121491.0.html
If you go that route, let us know how it works out! :)
Save a Tree, Eat a Beaver!
steved61
Re: Transcoder
« Reply #7 on: August 10, 2015, 11:16:44 am »
I ordered the Audio Authority 9a60. Will update when I get it.
Steved61
steved61
Re: Transcoder
« Reply #8 on: August 14, 2015, 03:12:55 pm »
Audio Authority 9a60 hooked up to a Sony KV-27FS120,all a get is a garbled screen ?
Any Ideas ? I though this was supposed to be plug and play. Am I doing anything wrong ?
Steved61
dmckean
Re: Transcoder
« Reply #9 on: August 14, 2015, 03:17:55 pm »
It's definitely not as easy as plug and play. You do have a video card that's capable of outputting 15khz resolutions, right?
steved61
Re: Transcoder
« Reply #10 on: August 14, 2015, 03:36:20 pm »
I'm using
Manufacturer   NVIDIA
Chipset   GeForce 9300
GPU   NVIDIA GeForce 9300
I also have a PowerColor
ATI HD 5450
On hand.
Steved61
dmckean
Re: Transcoder
« Reply #11 on: August 14, 2015, 05:34:39 pm »
What are you using for 15Khz resolutions? Soft 15-Khz?
steved61
Re: Transcoder
« Reply #12 on: August 14, 2015, 06:14:20 pm »
I'm trying too. But I think I'm in over my head. i'll keep playing with it over the weekend.
I'ved tried 2 VGA cables, 2 Component cables and the 2 Sony's TVs. Just to rule out any hardware problems
If I can't get this setup to work, I'll just get an LCD.
I'll return the transcoder and sell the 2 Sony's I have.
Thanks for all the help and encouragement
Steved61
« Last Edit: August 14, 2015, 06:53:22 pm by steved61 »
steved61
Re: Transcoder
« Reply #13 on: August 15, 2015, 01:45:40 pm »
If I get the ArcadeVGA card and use the transcoder to hook it up to the Sony' Then will everything work ?
Is the ArcadeVGA card powerful enough to run Carnevil ?
How about some of the newer emulators ?
Steved61
steved61
Re: Transcoder
« Reply #14 on: August 16, 2015, 08:04:07 am »
Anyone ?
If this is a workable solution I'll like to order the ArcadeVGA tonight.
Steved61
Dawgz Rule
  • Last login:August 22, 2024, 07:18:55 pm
  • The more people I meet, the more I like my dogs
Re: Transcoder
« Reply #15 on: August 16, 2015, 09:40:51 am »
Have you set your video to the appropriate resolution?  If not, try setting it to 640x480 and see if that helps.  The ArcadeVGA should also work.
« Last Edit: August 16, 2015, 09:47:15 am by Dawgz Rule »
steved61
Re: Transcoder
« Reply #16 on: August 16, 2015, 09:59:13 am »
Thanks I'll give it a try.
Steved61
steved61
Re: Transcoder
« Reply #17 on: August 16, 2015, 12:19:20 pm »
According to Andy at Ultrmarc  this well not work. So if anybody is interested in an Audio Authority 9a60 before I RMA it let me know.
Steved61
