Author Topic: Wells U3000 33" VGA monitor  (Read 866 times)
roothorick
  • Newbie
  • Last login:July 01, 2015, 05:13:39 pm
« on: July 01, 2015, 05:00:49 pm »
Single sync VGA only, doesn't need isolation transformer. The power harness I have for it actually plugs directly into the wall. Takes a 1V p-p signal typical of normal PCs, perfect for larger MAME cabs.
Beautiful color. Has the pincushion issue typical of these monitors, otherwise the geometry is pretty solid. All the other adjustments work far as I know.
You can pick up at my home, or I'm willing to deliver anywhere in the Appleton area, Green Bay, Oshkosh... if you're farther than that, I'll gladly drop it off at a shipper, but you'll have to work out the details yourself. 33" tubes are obscenely heavy and this one's no different.
$40, or make an offer.
« Last Edit: July 01, 2015, 05:06:55 pm by roothorick »
