Author Topic: Hide mouse when a game loads?  (Read 6057 times)
big10p
  • Last login:May 01, 2023, 01:46:23 pm
  • Mmmm, arcade classics!
« on: June 25, 2015, 09:48:01 am »
Anyone managed to do this in windows 7 when launching a MAME game from MaLa? I tried using nomousy.exe but it hangs when run from a batch file, for some reason.
Cheers.
BorgDog
Re: Hide mouse when a game loads?
« Reply #1 on: June 25, 2015, 12:11:25 pm »
I don't see my mouse cursor in Mala nor when I launch a game in either Windows 7 or 8, except when I right-click to get the Mala config menu.  Are you using yours for scrolling or selecting in Mala?
My Projects:
big10p
« Reply #2 on: June 25, 2015, 01:22:30 pm »
No, I'm not using the mouse to control MaLa, other than when right clicking to access configuration.
I get a second or so of the windows spinning blue circle cursor each time I launch a game. Strange that you're not getting this and I am.  ???
I think I'm using the latest beta version of MaLa. Are you using one of the stable releases?
behrmr
  • Last login:April 23, 2021, 09:17:13 am
« Reply #3 on: June 25, 2015, 01:47:15 pm »
What you're seeing is the busy animation.  You can change the "working in background" and "busy" animations to the clear icon.
http://www.jholjhaal.com/hide-mouse-cursor-on-windows-with-mouse-pointer-scheme/
big10p
« Reply #4 on: June 25, 2015, 02:15:35 pm »
That looks like a nifty solution. I'll give it a try, thanks.  :)
« Reply #5 on: June 25, 2015, 02:47:41 pm »
It shouldn't be necessary with MAME, but since nomousey hanging came up, the solution is to add "start " (including the space) before nomousey.exe
start nomousy.exe /hide
drventure taught me that.  ;)
I use it for Demul emulator.
« Last Edit: June 26, 2015, 09:46:49 am by BadMouth »
BorgDog
« Reply #6 on: June 25, 2015, 05:03:59 pm »
I have both latest stable and beta running on different machines.
Maybe because I have "Use fullscreen starting picture instead of starting window" checked under Options GUI Game Start/Quit?
Looks like you may be on to an alternate solution.
My Projects:
big10p
« Reply #7 on: June 25, 2015, 05:33:17 pm »
behrmr's tip worked... sorta. I still get a quick flash of the regular mouse pointer on game startup. I use a fullscreen starting image, BTW.
Thanks for the tip on starting nomousy.exe, BadMouth.
