Author Topic: A 0 games found workaround for MAME v.162 and later with Mala.  (Read 85873 times)
SGT
  • Last login:May 31, 2025, 10:10:32 pm
Re: A 0 games found workaround for MAME v.162 and later with Mala.
« Reply #40 on: January 05, 2021, 09:37:40 pm »
... and the method still works for Mame 0.227.   Someone should write a utility to make the job a little quicker?  ;D
Cakemeister
  • Last login:May 31, 2024, 06:23:16 pm
Old, but not obsolete.
1upmegaman
  • Last login:December 19, 2021, 12:39:43 pm
« Reply #42 on: December 19, 2021, 12:33:30 pm »
Well i have to thank the person who came up with this strategy it works but not all the way if u let mala pull the xml or even let cmd pull it and then use this strategy it does not change the exe u have to tell mala not to create xml then point mala to changed xml then u only have 3 times to start mala before it recognizes the change and locks then u must start process over agian. so the goal is to find a program that can turn exe scribble to normal xml format notepad++ must have this feature but iam a noob at at of this just like to play old games. IF ANYONE KNOWS HOW TO CHANGE THE EXE PLEASE POST.
